Exhaust parts picked up today. “tungsten” colored Cerakote applied. Reused the exhaust manifolds, heat shields are new.
Is cerakote rated to withstand that kind of temperature? Naturally aspirated headers get to around 1000 degrees. Turbo should get hotter. Ive never used cerakote so Im just curious because that looks really nice.
Beautiful! Good time to install the cooker! and man, at 1000 degrees those burritos will get hot in no time!
Where's the Check Engine light?![]()
I wanted to do one final follow up on the Cometic Head Gasket I used. The OEM HG measured 0.060" before compression. The published specs on the Cometic HG's are a compressed spec. I had 0.027" milled of the deck and head total and after going with a 0.066" new Cometic the timing gear slid on just perfect. My engine builder had some concerns here and was super happy with our results.
So the the assumption of 0.020" compression of the OEM HG was the perfect educated guess to use when selecting an oversized HG after machine work.
I assume the turbo is on it? Or are you going to drive it first non turbo to make sure bugs are worked out and it runs like it's supposed to and "break it in"? Did you end up buying a AFR gauge for it for the initial iteration?
