rushthezeppelin
- Joined
- Oct 14, 2022
- Messages
- 1,226
Decided to randomly jump under my rig and noticed this ><
Appears my front companion flange seals are bad. The larger inner seal is now on order from KC (figures, I suspect it's the inner seal and not the outer, which was in stock, but I got both coming as well as the one time use companion flange nut coming probably Friday).
Pulled the fill plug though and thankfully it doesn't appear I've lost much. Did clean it up with brake clean so that I can get an idea how fast the leak is. Hopefully slow, don't want to miss the Argentine run although I might be able to get the job done Friday afternoon. I suspect my breather might be clogged and this is the ultimate cause. I know when I was recently in my whole shifter assembly up top that everything was pretty dirty up there. Cleaned the transmission one up since I was putting in the short throw kit. Should have done the tcase too.
