SteveH
Drum axles - could be converted if late enough: https://denver.craigslist.org/pts/d/toyota-fj40-land-cruiser-axles/6646206453.html
definitely freeze it before going for it..
i have a inner axle bearing puller set that might work to pull out the old one, exactly as pictured above...you can see my shade tree use of said here...
http://risingsun4x4club.org/forum2/showpost.php?p=284232&postcount=370
shade tree in the sense that this set is designed for use with a 5/8 slide hammer, and aint no slide hammer in the world gonna pull them bearings.....your bushing? with a slide hammer? maybe.
but my bigger concern wouldnt even be the clearancing of the new bushing, or removal of the old bushing...
it would be the installation of the new one without messing it up...
i have a set of seal/bearing/race installers as well, designed to give before steel cause they are aluminum tools..., but that bronze is softer than aluminum...
you are welcome to use any of this stuff, and we could potentially try it together, but I would feel better if...
any of the old timers here done this ?!?
Did you measure the old bushing clearances yet? It might also be nice to know the bushing OD and the axle ID to see how heavy of a press it will be before sending them home. also the bushing ID compared to the axle OD... just to know what you are working with
They probably machine the new bushing to be as close as possible kinda guessing on how much it will compress when it goes pressed into the axle housing. You can never be sure that it will compress a known amount due to variations in the housing ID and the axle OD though they are probably really close to being consistent. you'll have to see if the new bushings you get from SOR feel the same and go in nice and then see if you need to ream/home it but you might get away with not needing it. At this point if it were me i'd replace them anyways no matter if you think they might still be good... but I agree that .08-0.14 doesn't seem like much. I'm glad the old one came out ok.
If the new one goes in super easy you might add some locktite bearing retaining compound to the OD before it goes in to help hold it better. If it goes in tight then no worries.
Thanks, Marco. The old one came out with about 4 wacks of the slide hammer, and the new one is exactly the same outer diameter as the old one. Seemed tight enough.
I'm more concerned, now that I've spoken to Spector Offroad, about having to take the outside lip off of the bushing they sent me. According to the person I spoke to, they only make one version of the bushing...well, actually two...one for the left and one for the right. So, depending on what year you have, you have to possibly modify the OD, or the ID, or both. If I had known this, I probably would have just had my wife's uncle make me oneNow, I'll see if he can take the wider neck off of this one and call it good.
All the fun working with 50+ year old vehicles![]()
Please attach a picture of you walking in pedestrian Japanese traffic.
