i went the mudrak way and got my output machined to take dual seals, but speedi sleeve is a good bandaid fix also.
wish i knew you were needing parts. i have two or three sets of brand new e brake shoes. still have a bunch of energy suspension tie rod end boots too.
sounds like it will be a good project and will be nice when it's fixed up.
Thank you, Ige...I might be interested in the tie rod end boots if they are black? I can't tell whether my ends are even able to accept the boot clip to hold the boot on!
That might be right. 1-1/8” is 28.6mm. Should be perfect.
Anyone on the north side have a 1-1/8” socket I could borrow for a few days?
90% sure i use 1 1/8"
my metri impact sockets stop at 27
so I am pretty sure its 1 1/8"
Look great Paul!
A couple thoughts:
-You may have a data plate mounted somewhere that may have an axle code (K41 or something, I don't remember exactly). If it has that you can tell what it left the factory with.
-Your pinion nut is probably a 29mm, which changed to I think 30mm in the early 70s. That's why it's an odd size.
Paul, it looks good man.
While you have the gauge cluster out, you might consider an LED upgrade. I yanked my bulb shields off and installed some LED's from www.superbrightleds.com and the difference is I can read my gauge at night. I would also suggest creating a pigtail/braided ground wire from the gauge cluster to the body. It helped me get better signals on all my gauges and improved a "flickering" LED light.
I also repainted my gauge cluster face and I have some new "hunter orange" model paint to touch up the needles and make them really look new again. You're welcome to it. It is only a little more time while it is out.
