SteveH
I just went through a lot of agony with the rear drums on my '78 FJ40, after replacing the shoes. I was convinced I had air in the lines and/or the new MC was bad, as the pedal would go far down to the floor before any braking action. I then repeatedly adjusted the rear drums and let the new brake shoes 'bed in' a bit, and now all is well. I was surprised at how tightly the drums and shoes had to fit before I got any sort of normal pedal action. The result is that I can now feel the rear brakes working and overall braking is a lot better. Having OEM front disks didn't 'save' me from any of the pain you're feeling. I bled about a quart through the system, and eventually concluded that it wasn't an air-related issue.
So, my .02 is to keep carefully adjusting each set of shoes until they are grazing the inner drum surface, and this will eventually get you a firm pedal (assuming no air). Then drive it, and keep readjusting as the shoes bed in, and you will get to the happy spot.
