LARGEONE
I posted another bodywork post, but I'll document here as well that I had a little trouble with the spray can primer. I wanted to make sure I had primer on if I left bare metal on the panel overnight, because the metal flashes really fast. So, when I sanded the primer back down and did some putty on a few spots, I re-sprayed primer and it went on really rough.
I am using can primer for now, because I am really only putting a cheap cover on this for now. The inside is what I am more concerned about, since it will need to last forever. I am seam sealing everything around the repairs and along the rear sill, so hopefully it will be the last rear sill this 40 ever sees.
