Fuel Issue 94 FZJ80
Skw6r
Brand New
Been trying to diagnose a fuel issue I've been having since I did a long hot road trip about a month ago through Wyoming and Montana. 94 FZJ80 218k miles.
Symptoms:
- Rough Idle when engine is cold
- Bogged down at take off from idle when cold. Engine stumbles, pop sound (not sure if knock or exhaust backfire)
- CEL 26 (rich) about 2 - 4 minutes after start, disappears about 2-4 minutes later consistently. (maybe associated with open loop to closed loop transition?)
- Smell from exhaust on cold start, slightly sweet. Can't tell if fuel smelly or coolant smelly, hopefully the former
- Strong fuel vapors from charcoal canister on long or hot drives (replaced original with Duralast VC120 about 3500 miles ago)
- Significant fuel vapor pressure venting from tank when opening the gas cap on long or hot drives - I suspect my gas has boiled at times.
- Engine run-on during a 5 hour drive at 100F when I suspect the fuel may have been boiling.
- Maybe slightly worse MPG lately but hard to tell as I've added weight. 9-10MPG highway. Whereas I usually am at exactly 10 combined. 35s, very heavy.
- All rubber hoses under the engine have less than 5k miles on them and have been smoke tested for leaks.
- Fuel pump, sender, and filter replaced at 187k miles.
- All 6 injectors replaced and have less than 5k miles
- VSV replaced - less than 5k miles
- FPR is original, no fuel detected in vacuum line
Thoughts I have are that there may be a restriction in the fuel return line or malfunction somwhere within the EVAP system. I did a visual check of fuel lines from tank to engine bay and canister purge lines and didn't see any obvious kinks or signs of damage. I have not yet tested fuel pressure.
RayRay27
RS Club TLCA Delegate
Thornton via Boulder
Check your O2 sensors. One or both may be bad causing the truck to run rich and throw a code.
