Early 100 series EFI relay fuse bypass… epic saga.
madorbit
The fam and I jumped in the hundy and drove to Michigan the week before last. Of course you drive 1,200 miles, one way, in a car with 360k on it!
We get to Des Moines for the night. I pull up to the foyer of our hotel, get everyone unloaded, go to park the chariot and I get the crank-no-start condition with the flashing security light. What the what? I spend about a half hour and get it to fire up. Thinking it’s a security key issue. Fiddle with some fuses because I have no tools. I get it started multiple times… Crisis averted. Tools purchased.
Drive about another 7 hours the next day. Get to Indiana… Portillo’s burger and a Costco fill up and damned if it won’t start again. Thinking it’s the same issue I reset the computers. Nothing. Drat. We try for about a half hour before I call my mom who thankfully lives nearby. Get a rescue ride and a tow truck to grandma’s house for the night.
At this point I’m at a loss. Can’t sleep thinking worrying. You know the routine. I come across the well known issue of the damned, to h-e-double hockey sticks, EFI Relay fuse. Do you have a flashing security light and no check-engine light when you turn the key on? Sure do, Bob! I pop the cover off the efi relay, jump the main bus bar to a +12v lead and she fires right up. Mystery solved.
Now what? I get the point of my test light into the spring of the fuse terminal and give it hell. It works for another 4-hour drive to Chelsea MI where we stop for the night. I park the beast and try starting it a few times and again it’s not cooperating. My panic is low at this point because I kinda have an idea of what’s going on now. I’m able to get it started in just a few minutes of tinkering under the hood poking at the efi fuse clips. Solved but not fixed.
Anyway. In the morning we visit the local parts store and I get some wire, terminals, a crimper, and a Bosch style relay and we’re on the road again. I don’t have AHC on my truck so I use the 50A port (with a 20A inline fuse) on what would be the AHC Pump relay. The temporary bypass relay fits under the cover and is reliable the rest of the trip. When I got home I grabbed the EWD and researched a proper fix. I tried to open up the main fuse box to maybe tighten up the fuse clips… no way. Bypass it is.
A little more research says Toyota kinda overloaded this circuit. It’s ok until 25 years later and multiple 10 hour drives taxed it beyond its limit. Thankfully it didn’t melt anything.
I discover with the EWD that this 20A fuse has three main functions.
1) Always on Computer memory.
2) [EDITED FOR ACCURACY] key on B+ feeding the fuel pump ECM > fuel pump. (High current circuit)
3) And then the computer & every sensor and throttle body motor and the kitchen sink that runs the engine.
I decided I’d split this off to three separate circuits. Three fuses & two relays.
1) A light duty computer memory fuse (10a)
2) A heavy duty relayed (key on) B+ feeding the Fuel pump ECM.
3) A heavy duty relayed (key on) powering the engine computer, all of the sensors. 15A fuse before the relay.
Researching the dual relay option… they’re both triggered by the ECM. When the relays close there’s an induced voltage that can damage the transistors in the engine computer over time. Most modern relays have a resistor OR a diode in the low current side. The original Denso relay has neither, but it’s specifically designed with the computer in mind & it’s only one relay. For our application, since we are, potentially, doubling the relay collapse induced voltage I want to use the diode style relays. I do NOT want to buy a new efi computer.
I have the perfect fuse box in my electrical junk bin. && all of the crimp connectors & seals (because I’m ridiculous).
Ordered the correct relays and some properly colored wires to pull these circuits out of the stock positions and feed this Littelfuse distribution box.
Got to crimping tonight and I’ll be installing it tomorrow. More photos to come.
Good times!
(Fuses in this photo are for illustration only) not the right rating… I need to raid the fuse pile still. && yes it has a lid and is more waterproof than Toyota’s fuse box. Really nice product actually.
madorbit
I suffered a slight delay in installing my fix… supply chain issues. LOL. These little GT 280 “relay key” cavity plugs are brilliant but kind of difficult to find…
The purpose of this little bit is to prevent my dumbass from installing the relays backwards. Because… I at least know myself enough to prevent it physically. 😆
Anyway. I was wringing my hands over where I was going to put this distribution block. I decided to take the whole thing apart and design on the fly. I had enough lead on the block where I could put it kinda anywhere.
It turns out there is a perfect amount of plastic skirt on the OEM fuse block for some nutserts and some small screws. (I have a bin of short FJ40 rear door hinge screws).
I should have taken some more photos of the process but I wasn’t thinking about sharing it here while I was installing it.
And…..
Waterproof.
madorbit
I was going to just unpin the original wires and put them in their own housings so this could be plug and play. I decided against that level of retentiveness and just unpinned them and used crimp connectors and gobs of heat shrink on each splice. It’s permanent anyway.
Clean and sturdy.
madorbit
An extremely important note for anyone adventurous enough to tackle this…
Diode bridged relays are very sensitive to reverse polarity wiring.
IF YOU WIRE THEM BACKWARDS YOU WILL FRY THE TRANSISTOR IN THE COMPUTER THAT DRIVES THE RELAY.
so forewarned is forearmed. Don’t wire them backwards. I probably checked mine 5x before turning the key. 😬
It’s working just as intended now.
Now I need to drive another 500k miles to test it fully.
Cheers!!
~Mike
