Found out why FJ60 tail running lights aren't working (sort of)
IH8RUST
I posted about this on Mud and ended up spending the majority of the day troubleshooting to determine why only the tail light, running lights, and rear markers wouldn't turn on. Brake and signals work fine, kept looking, until I remembered:
This is located under the driver's seat, specifically between the floorpan and the inner rocker (is that what it's called?). As you can see, the wire harness is in poor condition. I haven't pulled it yet, and upon closer inspection, there might be a short somewhere, as the fuse box is receiving all 12V. The issue is between the fuse box and the rear quarter panel, and this is the very likely culprit.
It’s so bad.
IH8RUST
Look at this carnage!!
IH8RUST
Patched them up. Dave in Denver would be proud of me.
