My daughter was driving her 1984 FJ60 when it suddenly died yesterday. No electrical power to anything, lights, starter, nothing, jumping does not do anything. I had it towed back to her place in Evergreen and went out and checked it out today. My first thought was fuseable link. After identifying where it was (I think I identified it?) it looks like a short three wire pigtail just downstream from the positive battery terminal, starting with a single wire on the battery side, splitting into 3 wires at a cylindrical connector, going into another cylindrical connector after only a couple inches. I measured battery voltage at the downstream side of all three terminals at both connectors.
Battery is a healthy 12.5 volts, as were the measurements on the downstream terminals of both of the connectors I assume are the fuseable link. The wires from the fuseable link disappear into the loom that goes into the left (passenger) firewall and presumably route on the passenger compartment side of the firewall to the fuse box on the driver's side. None of this is visible with all the heater/AC stuff under there.
I pulled one of the two headlamp fuses and measured no volts on either terminal, so I assume there's an open somewhere between the fuseable link connector and the fuse box. On an FJ60, like an FJ40, headlights aren't switched through the ignition switch...but I just noticed that they go through a relay first so...IDK. Pouring over the schematic, I can't for the life of me figure out why there isn't any power anywhere that I checked, yet there appears to be power at the downstream side of the fuseable link. I would think with the power split 3 ways there ought to be power on at least one or two of those circuits. One of them goes to the ignition switch, one goes to the alternator/regulator, and one goes to the fuse box. The only one I verified has no power is the power to the headlight fuse in the fuse box, so there's that. Maybe I should have investigated fuses more? At the time I was looking for something unswitched, and didn't notice that the headlight relay was upstream of the fusebox.
I asked and she reported no burning electrical smell prior to the rig dying. Lineage of this rig is, is many years ago past Rising Sun Commander and current TLCA Advertising Sales Manager Chris Hatfield sold this rig to my daughter's grandfather, who sold it to her, it has 238k miles on it, not a hell of a lot but it isn't in great condition. It has body parts on it I got from when Kevin Ehrlick was parting out a 60. I spent way too much time figuring out a bunch of the wiring I was looking at was non-stock for electric trailer brakes. I think all that rubbish needs to go.
My thoughts are: (1) replace the fuseable link anyway just to be sure (does anyone who's parted out a 60 have one lying around I could buy?) and (2) drop the fusebox and inspect the back of it to see if there's anything obvious (doubtful, but you never know). I suppose I could check the other two places power goes other than the fusebox, the ignition switch (looks like a PITA) and the alternator/regulator (not a PITA).
What thoughts does Rising Sun have as to where to look and what might have failed? TIA!
