Stuckinthe80s
I've been having this weird issue with my speakers for the last year or so that I think may be a ground issue.
Last year I installed 4 new speakers, one in each door and a new head unit. It worked great, and usually works great until it rains. When that happens, the normal sound goes away and a high pitched squeal happens until I blow the 10A fuse that feeds power to the radio/interior lights. Once everything dries up, I usually replace the fuse and all is good again until it rains again. However, now the sound is pretty constant so I'm trying to figure out the source.
I've wanted to track this down for a while so I started troubleshooting. A lot of things were changed at the same time I did the radio install so I'll list those out now:
1. Replaced factory antenna with CB antenna mount from Wagon Gear. This requires a ground path as well as utilizing a CB/FM splitter so it can act as both antennas
2. The passenger rear door did not have a factory speaker. It was weird, there was a speaker cover, a wire ran and a hole cut out for one but nothing there. I spliced into the wire that was ran and all was good.
3. Around the same time as the speaker install, I installed a water bladder in the rear passenger quarter panel. This required the removal of the factory amp and sub woofer. I didn't terminate the speaker wire, just pulled the plugs out of the way and installed the bladder.
4. I utilized a wire adapter to plug into the factory harness because why not.
SO, my troubleshooting steps so far:
1. disconnected the antenna, played the radio, still had the squealing.
2. I pulled the head unit, disconnected the harness, turned the truck on, still had the squealing.
This is when I stopped because it is really weird to me. Doesn't the radio provide power to the speakers? How are the speakers making any sounds if everything is disconnected? I'm to the point now where I'm just going to run my own wires to each speaker and bypass any of the factory stuff. However, ground issues scare me from all of the horror stories I've read on people's trucks catching on fire so is this what that is? And if it is, how are the speakers making sound if there is no power applied?
