I think you need a wheel on the other side to help spread out the load :)
The picture was taken after I installed the drone lift system on top. Kinda noisy, but seems to hold the load ok.
Started the 30K service on my LC-250. Standard array of filters and crap. Need to source differential and transfer case oils to finish up next weekend.
One item of note for 250 owners. Clean out your hybrid battery filters. See page 570 in the owners manual. Mine have been cleaned already decided to replace at this interval.
Part numbers
G92DH-34010
G92DJ-34010
One item I’m pleasantly surprised about is brake pad wear. At this rate I think 100K is realistic out of the stock pads. Considering I’ve got over 12,000 miles of towing in this is impressive.
Had some more time today to get the wiring sorted out on my oba setup. Hopefully I’ll get the tank mounted sometime next week. At idle it only builds 120psi, but with the hand throttle set to 1,500rpm it builds to the 146psi shutoff pretty quickly.
—>youtube link of it running.
View: https://youtube.com/shorts/zbk5lUHy7SM?si=xk-fgoOLjZ2-uIjR
I wish I would have ordered that manifold before Joey closed up. I've got the York bracket sitting in the shop. Pulley is already on the crank.
I just bought it this past October myself. This company on eBay bought the vast majority of his bankruptcy stock.
https://ebay.us/m/RMMIg5
They might have some more for sale still along with other Witsend goodies.
That manifold is available through McMaster.
unimogguy
Wheat Ridge, CO
A 45 parts lot I previously purchased finally got sorted (kinda), spun the 💩45 around using Subaru while blocking traffic on the street, PO V-8 engine mounts cut off, almost have the trans stabbed, 3 hinges and license plate holder installed on early FST 40 tailgate thanks @nuclearlemon!!!, mocked up a 25 bezel and aprons to see if I wanted to swap them out for a different look.
Got my Boslla led bulbs installed in the 80 today. Ran into some issues with getting the bulb adapter to lock into place on one housing ..but pretty sure that’s an issue with my bulb socket. Used a little hondabond to lock it in place and we’ll see how it holds.
It’s crazy but I can actually see the road again which is greatly appreciated on these narrow country back roads. IMG_7134.jpegIMG_7139.jpeg
MarkEva
Today I finished installing 4 33" K0's and tomorrow I will do the fifth. A few days ago I soldered my broken wheel speed sensor wires and the dash lights went out. It made me so happy to have a dark dash.
MarkEva
That's really digusting.
dan1554
Chaffee County
The rat was a stowaway from Texas and is long, long dead. Mummified, but only after liquifying in to the carpet and one of the setbelts. The owner is planning on having seats reupholstered so Im taking that rear bench seat, aka rats nest, and bagging it up for that guy. The old carpet is pure filth, whats pictured is after it was vacuumed. Might be a good candidate for one of those youtube carpet cleaners.
