Curious to see how you like this and what the display looks like hooked upSwitch Pros are expensive (600 bucks)! I picked this Auxbeam switch panel for 133 dollars from Amazon. The panel and the bottom of the fuse panel are metal and seem very well constructed. Going to start installing this and my KC lights Sunday.
I had to use ratchet straps to realign my rear end last time I took my panhard off when I was doing the rear suspension. That was such a pain. Probably struggle bussed with that alone for like 45 minutes before I thought of using ratchet straps lol.I put the delta rear panhard bracket on my 80 series. Another 30 minute job turned into a 3 hour struggle. Lol. Tough to get the upper bolt to line up for some reason. Threw a dobinsons lpsv bracket on too. That was significantly easier. Think I broke a finger though when I smashed it.
getting those bolts to line up is a PITA. I have done two of those now, and haven't learned a trick other than take frustration breaks. LOLI put the delta rear panhard bracket on my 80 series. Another 30 minute job turned into a 3 hour struggle. Lol. Tough to get the upper bolt to line up for some reason. Threw a dobinsons lpsv bracket on too. That was significantly easier. Think I broke a finger though when I smashed it.
What make did you go with I've been eying those for years.Added a Gullwing window to the rear. It’s from solvefunction. Terrible experience with that guy for the window. Took forever to get, no communication, missing pieces, etc. I like the window. Time will tell if the seal is waterproof or not.
I think there's one for sale on facebook marketplace right now.What make did you go with I've been eying those for years.
It’s solvefunction. He basically stole Landcruiser Phil’s design and made one out of acrylic glass. I wanted glass not black metal so went with this. We will see if it’s weatherproof enough. If you’re thinking about one I’ve been thinking about getting some more acrylic glass cut and making my own. There’s a diy thread on mud with supplies needed.What make did you go with I've been eying those for years.
I remember seeing one as well. I bought this only because it was a Black Friday deal and was $100 less.I think there's one for sale on facebook marketplace right now.
I feel you, after doing the second side of my rear axle seals my light has been on and off, seems to be somewhat temp dependant but it wasn't doing it before I did that job.Dangit I must have pulled on the abs sensor wire doing the panhard bracket. Now I’m getting a constant abs light![]()
