Stuckinthe80s
Wait, is that a Supra back there? You don't have that in your sig!1FZ rebuild party.
Noise and reduced ring life.
How does forged pistons cause piston slap?
Was considering Forged Pistons but the cost seems pretty comparible to OEM so may just go that route (though probably with a +1) since I doubt I'll ever rebuild again.
Did you guys call up somebody like JE and see what their recommendations were and how much it’d cost?
Yeah piston to cylinder clearance is for sure something you talk to the mfg of the piston about. I was mainly asking because maybe there's a better than OEM option that takes a more standard clearance that might be more economical. I'm also not sure what OEM pistons cost or have any experience on their robustness/reliability. It seems like they are fine from what you're saying. I assume the Pistons that came out of that motor are no good? Do they have a lot of scuffing on the skirts? How do the bores look are you going to over bore it? One reason to go with aftermarket Pistons would be if OEM ones don't come in a larger size though that may not be an issue here. Also having an engine builder with experience in these motors
T, particularly boosted, probably trumps any advice I could give I'm mainly just curious. That experience alone is worth a ton, you're lucky you've got him. What rings does he prefer? We've used total seal rings on turbo motors with reasonable success but we've also never thought about making anything last over say 30k miles... Also I assume stock compression ratios and cc everything to verify? An over bore will affect that of course and is changed with Pistons. Fancy head gasket or OEM?
