• SEPTEMBER 2026 CLUB MEETING: EARLY START TIME
    Hi Guest: The next RS meeting will be Wednesday, Sept. 2, 2026 at Fairmount Park in Golden.
    • Location: the meeting will be held outdoors at Fairmount Park in Golden.
Knitty Gritty - Yarn Cruisers 1990 FJ80
Capriblue45
Dom, the rolled 80 I purchased still has a tank that I do not have a need for. I don't know if it is the same tank as a 90 or not? I have not looked inside yet but can in the next day or so.
allen.wrench
Syracuse, UT
What you took out doesn't look OE to me. The wire splice and hose clamps...
That's what I was going to ask about. Worm gear hose clamps always catch my eye after having ripped open my skin one them enough times.
A guy in my Kokopelli group last year had an 80 with two stock Toyota fuel tanks. One was the stock 80 tank, and the second was a stock Toyota Tercel tank that he said fits perfect in the spare tire holder space. He'd set it up to have a pump, with valve & hose to "manually" transfer to the regular 80 tank or to a jerry can or to someone else's truck. Food for thought. Maybe if you're unable to find a replacement 80 tank, consider a Tercel tank. Or do both if you can :D it seemed like a cool setup and for all intents/purposed used only Toyota parts.
Allen
Allen
Similar idea, but there's a company called Trail'd that builds 6 & 14 gallon donut-shaped poly tanks that secure with the spare tire hoist. I was going to do an onboard water system (which I'm rethinking), but it could just as easily be used "off label" for fuel. No mounting fabrication required - literally just hook the spare tire holder through the middle and hoist it up until it's tight.
DomOfTheDead
Event Coordinator
lakewood
We will be picking up a tank and sender, thanks to @Capriblue45 , and plan on just swapping out both.
The wiring was spliced on the existing sender at some point due to connector failure that also failed as i disconnected it from the pump. I have found the smaller style pump which seems to be a later model 80 pump, instead of the earlier 3FE version.
The fun part now is pumping out the 3/4 full rusty tank to begin removal. :cautious:
Capriblue45
Dom I used a hand transfer pump like this to empty out the tank before I dropped it. 8 Bucks at harbor freight.
Does an 80 not have a drain plug in the bottom of the tank like a 60?
I still have 2 gallons of fuel (of 14g total) that I drained from my 60 … I think it’s from 2015 if anyone wants if for free! 🤣
Capriblue45
I used the drain plug when I cleaned out my 60 tank but didn't want to risk damaging a very clean tank for Dom and Brandi.
Yarn Cruiser
Thank you so much! What size shirt do you wear?
Capriblue45
A large in most brands.
Damn that IS clean. And yeah, sometimes if the plug hasn’t moved since it left the factory, there’s a risk of damaging the threads. I think I came close to that when draining mine … but I was eligible for a new tank under the recall so it only had to last a month!
Capriblue45
I wonder if they still honor the recall on the 60 tanks as I can guarantee mine is original and it would be nice to replace it when I do the chassis swap.
DomOfTheDead
Event Coordinator
lakewood
my tank was clean like this when i did the fuel pump on my 80 after it failed coming home from Argentine a few years ago, I was horrified when I opened this tank and found this rusty mess (insert Nietzsche abyss quote here)
I have a cheap drill powered transfer pump that I have been using that takes some of the forearm work out of the equation but I will use the tank drain plug as I did not know about its existence. Once again, too many years of working on GM products has me expecting the worst for maintenance based design 😅 :cry:
When i did the fuel pump on the 4Runner i used a motorcycle jack to lower and raise it... worked great!!! the tank was full too!
Stupid pump died right after getting gas. drove home, went to leave and nothing.
allen.wrench
Syracuse, UT
the 3/4 full rusty
I can think of a few ways to dispose of it once you get it out :) I still have that 3 gallon can from last October in Moab. We burned a little bit there. A bit later at home I gave 1-2 gals to a friend visiting who was driving a rental. I used the remainder in my pressure washer to get mud off my truck. Worked out great.
Being so rusty, maybe the best option is to use a rental for disposal. I'm not condoning use of rusty gas in any vehicle, but IDK, it might be nicer compared to normal treatment rentals get.
LOL! I cannot help but last cuz I know what you mean.
@Crash 10000% agreed. Murphy was an optimist!
Allen
Yarn Cruiser
Today was an extra special day! Knitty Gritty arrived home in one piece after her very first trail! She did great, a little more tweaking but extremely happy with how she performed today. This wouldn’t have been possible without the help of several people and the biggest thank you to @DomOfTheDead! Aside from being the best mechanic ever, he’s just extremely supportive and encouraging to me. Can’t wait for many more trails in his and hers models with my favorite human.
