Yarn Cruiser
- Joined
- Jun 15, 2020
- Messages
- 1,015
@DomOfTheDead I am so lucky to have you.
A scraper ended up as my go to also, I tried using a wire wheel cup on a drill but that method made a huge mess.I just fixed my power steering leak as well! A scraper ended up being the best tool for cleaning haha. It was really caked on there!
I didn't have an issue with the 7 different soft lines on my FZJ but this FJ only has 4 total soft lines; 3 up front (calipers to axle, frame to axle) and rear is frame to axle. The troublesome one is at the rear frame hard line location, maybe the flare wasn't done exactly the same and the fitting threads aren't engaging. My hand were cramping and I gave up after struggling with it for over an hour. I will make a second attempt before I purchase another hoseSamsies on the brake lines. I did the three frame to axle lines a couple weeks ago and it was pretty frustrating with all of the brake fluid dripping down my arms and in my face.
I remember that Slee line wasn’t an OEM style fitting for me either, but I just did the best I could and snugged it down. So far so good. But this was on my FZJ80, not sure if Knitty Gritty is the same or not.
Sometimes when the flare nut is tightened down too hard it causes a deformation in funnel-shaped piece on the hard line. You can get the hose off but getting a new one on over the deformed fitting is impossible. It feels like it goes in part way, but not enough to grab any threads. I really should replace those when it happens, but I usually stuff something in the hole of the hard line and start filing around the circumference of the funnel-shaped part until the hose will slide on smoothly.I didn't have an issue with the 7 different soft lines on my FZJ but this FJ only has 4 total soft lines; 3 up front (calipers to axle, frame to axle) and rear is frame to axle. The troublesome one is at the rear frame hard line location, maybe the flare wasn't done exactly the same and the fitting threads aren't engaging. My hand were cramping and I gave up after struggling with it for over an hour. I will make a second attempt before I purchase another hose
