Bender - The Silver 60
I know of a local guy who is restoring a Silver FJ 62, but will let him post if he want's to. It's going to be very nice as well.
As far as sound deadening, I really like it in my 60 but also added aftermarket carpet at that same time. It made a good bit of difference, IMO.
The areas of rust and repairs are Identical to the ones I had on mine, not just outside but inside.
So heads up 60 folks, reading/following.
Love your build
What product did you go with for the deadening? I also have new carpet on the way and I expect there will he a huge noise reduction anyways with no more holes in the rear wheel arches.
Day 15. 2hrs
Not much action today. Frame sandblasting on Monday!
fyffer
I personally used Siless Hybrid 3 in 1, some sticky stuff and don't do it if it's warm outside. But pretty easy to trim. I posted it here on the forum somewhere. Check it out on Ama zone.
Just a Thought as ease of access to bolts inside, check the Body mounts. I replaced mine a while back, the rubbers where a little rotten.
Just be aware that the body mount bolt and the sleeve it rides in can weld themselves together after all these years. I had to go to some extraordinary lengths to remove the two behind the rear wheel well. It was not fun and required chaining the frame to the ground. Those two were huge bitches while the others just slipped apart.
Nothing yesterday
Day 16 - Sandblasting is magic.
Body work is done and the frame was blasted for paint prep. The gas tank will be dropped before final paint and will be painted the same black.
Great news that there was no unknown frame rust present. About what I expected and easy to patch.
@Rzeppa Look like some familiar spots? Same exact area on the shock crossbar.
Where did you source the new mounts? This is on my list. Did you find new oem style rubber? I have only found used rubber or poly kits.
Yes, crossbar rust in same places, both crossbars. On the one for the shocks, I sleeved both ends and rewelded. Your inside frame rust looks worse than mine was, maybe because mine was originally an Arizona truck and had literally no rust when I bought it in 2011, so everything I experienced is thanks to CDoT's mag chloride, and to a lesser extent NaCl. If you go with the 4x4 Labs rear bumper, that rear crossbar gets cut out and replaced with a new, beefier crossbar.
What size Tank was that again, looks a lot like my 38gal.
I was listed as a 40 gal LRA but it looks a bit different. It does have the LRA stamp, maybe they changed the design? Good chance its the same as yours.
I don't know if it is the forum software or what, but a bunch of the images in the post above appear duplicated multiple times when I scroll through it. Good pictures though!
The wheel chair seems like a brilliant idea. Is it common in shops like this or unique to the Rust Doctor?
I’m guessing he needs it.
