- Joined
- May 4, 2019
- Messages
- 1,363
Located the source of my exhaust smell in the cab.
Wow that bumper ate that freaking car for lunch and is barely scratched. Is your frame all gravy from that?It’s not something I did but someone tried to open the side of their Chevy Cruz with our Bio rear bumper.. they ran too so if you see this thing, let me know.
View attachment 115295View attachment 115296View attachment 115297
The frame is fine from my first look. The main damage to our car is barely visible, but I imagine insurance will total it. When their windows exploded it peppered the quarter panel like someone started to blast it with glass beads. You can sort of see it in the photo, and it goes down to primer/bare metal.Wow that bumper ate that freaking car for lunch and is barely scratched. Is your frame all gravy from that?
You made real quick work of that! 80 looks great!!Success! Started right up. Not codes. Lockers work. No leaks. D-light illuminated! Dobinson's rear springs are way to high. Bought them used and they were supposed to be 2" but are more like 4". I guess I need some weight back there.
View attachment 115332View attachment 115333
I need to paint my wheels that color. Is that the Duplicolor wheel paint?Success! Started right up. Not codes. Lockers work. No leaks. D-light illuminated! Dobinson's rear springs are way to high. Bought them used and they were supposed to be 2" but are more like 4". I guess I need some weight back there.
That stuff looks and works great. I painted our 100 series wheels that way 4 years ago and It still looks good.Yup. Graphite Grey with Gloss Clear. Lays down real nice.
Great to learn that Dan! Did you replace to O2 sensors yourself or pay someone else to do it.? Usually they are rusted in to the exhaust bungs and super hard to remove.Finally solved the misfire issue on the 80. After it threw a P0125 code which was diagnosed and solved by discovering zero signal from either oxygen sensor, both sensors were replaced and the signal was good from both with no more P0125 code. Still idling rough and misfiring with an occasional P0303. Figured the spark plugs were overdue, so I went to replace them and #3 was literally finger tight. Replaced all 6 and now she is purring again.
I swear every time I have an issue I expect some catastrophic failure that is going to be super expensive. Then it turns out to be the simplest thing. Land Cruisers are frickin awesome.
Yeah I paid Joe at CTS. He had the whiz bang diagnostic computer, so I let him have the pleasure of dealing with the sensors.Great to learn that Dan! Did you replace to O2 sensors yourself or pay someone else to do it.? Usually they are rusted in to the exhaust bungs and super hard to remove.
