RDub
Finally got the ham radio installed in my 60. Went with the Yaesu FT-2980R 2m rig. I decided not to drill holes in any sheet metal so I mounted it similar to an installation I saw on MUD.
What took the longest was figuring out an antenna mount that wouldn’t require drilling holes. Went with passenger fender mount, and built a custom bracket that uses two existing holes in the fender well. I settled on 18ga 304 stainless material as a decent compromise between stiffness and hood/fender gap clearance. Hard to make it stiff enough so I had to add a second piece. The three screws were cutoff after they went in and peened over, like rivets. I used a small piece of 3M VHB tape to try to stick it down to the horizontal lip on the fender well. Probably a lot of overthinking going on here. I need to come up with a slicker way of managing the coax.
Not much of a gap between the hood and fender which made it a challenge. Seems pretty stiff now, but added a piece of thin rubber as a protector. I used a Diamond NMO mount with skinny coax, which Diamond assured me will handle the 80W the radio can put out on high power.
The fender mount is not optimal but it’s fairly clean and has worked well so far. Time will tell. Overall I’m happy with how it turned out.
