    Click here to register now..
My Sisters 40
kurtnkegger
Denver Burbs
Drew, I butt welded it. The original looked like it was about 16 gauge, and the only tube the vendor had there in stock was 1/8th inch. About twice as thick as the OEM tube. Since the two side walls were so different, I couldn't really put a sleeve in there. I ground a nice edge off of the new steel, and the way the cutter went through the old stuff gave it a bit of an angled edge as well. There was really a decent area to fill, and since the new tube was so much thicker, I was able to leave the molten puddle there longer, and then dance it to fill the crack, and get good adherence. I honestly think I got a good strong weld in the joints.
As far as welding the rear quarters in, it wasn't too bad. In retrospect, I should have been more cautious on the top cut, and left the small lip of steel for a little backing (If that could be done) Just something I thought about as I was starting to fit the pieces. The long vice-grip clamps (like about a 10" reach) were real handy to help keep the quarters in place while the first welds were being done. There was about an inch that I had to trim off at the back once it was worked around.
All said and done Drew...I've seen some of your work, and you wouldn't have a problem getting them on...
kurtnkegger
Denver Burbs
The old steps were pretty rust rotted, and I figured it would be easier, and better to just make some new steps. I used 1/8th inch diamond plate, as well as 1/8th inch cold rolled flat stock that was 1 1/4" wide. I measured the old diamond plate, and should have measured the over all dimensions....anyway, the new steps ended up about 3/8" shorter than the old. Not really enough to notice, but now we all know....
I welded about one inch long stitches on the underside, and did a couple of half inch welds by every mounting hole. Welded the gap around the outside edge, so when cleaned up, it would look like one piece.
kurtnkegger
Denver Burbs
I got the grinder with the hard wheel, and took the weld close, then finished it up with a flap disk. The support was made from some scrap "C" folded sheet, that was 1 1/4" as well to keep the support. Welded in a nut, and fit the steps to the side of the 40. Once in, I clamped the support up so the nut matched up to the support piece. I tack welded in place, removed, finished welding, rattle can, and replaced.
Nice sturdy steps in place now...
SteveH
Colo Springs
Running boards = wow. Impressive.
simps80
Arvada, CO
love the steps.
this thread will be real nice inspiration!
do you have a brake you are making bends with?
kurtnkegger
Denver Burbs
Mike, no brake, just a vice and a piece of pipe thats about the right size. I bent the flat stock for the steps cold, it took a little time and the little bend took some hammering to get it to cooperate...
aprosise
Kurt, this is making me want to start on my 40! Very inspirational!
Nice work.
again, freakin' awesome job!!!!!
simps80
Arvada, CO
how did you do the mounts for the barn door hinges with the new rear fenders..
did the new fenders come with nuts on the back..i can see in post 48 the top two screws are still there but can't tell what the rest were part of..the new fenders or some support piece?
i checked jeff zepps resto page too, its a 76 so different..but no detail on the holes for hinges
..just curious
edit:
found some good detail of the channel behind the quarter skin here:
http://forum.ih8mud.com/threads/bumps-on-my-78s-rear-tub-fenders.235482/page-8
kurtnkegger
Denver Burbs
Mike, The top two holes are inside the top rail, so I left those to reuse. They weren't rusted, and worked great. The bottom holes were just two free nuts on the inside. I used flanged JIS nuts instead of the nuts and washers.
The bottom hinge was fastened to a plate that was rusted out, so I got the measurements, drilled and tapped the holes in to a new piece of 1/4" plate at the right distance (M6X1.0) and fastened them in.
After I broke the old bolts off the plate came out, so I don't think it was welded in to place. I didn't weld the new plate in.
kurtnkegger
Denver Burbs
Not much to report from the weekend....
Cut the reverse light hole.
Made door limiter brackets, and welded them on the half doors.
Rezarf
In Uncle Ben's Shadow
Kurt,
Do you unplug the battery and or do anything else before welding panels on the rig? You've inspired me to get after my 40's rust.
kurtnkegger
Denver Burbs
You know Drew, I never even thought of disconnecting the battery...until you mentioned it. I never thought the "computer" was that delicate to where I could hurt it. It probably would be a good idea to do that.
The only thing that really made me pucker was welding right next to the gas tank. I put a heavy plastic sheet on the filler part of the neck, and then put rags over to protect from sparks burning through. Since its outside, I wasn't worried about accumulation of fumes.
As far as progress...I made a couple of plates to cover the hole for the door crank. The guy I got them from said he put speakers in there, but there wasn't any extra holes. I painted with some "stainless steel" color paint, and the color matched up ok.
I started taking emblems and some trim stuff off in preparation to go for paint. I put a bungee cord over the hood to stop it from blowing up in case of a wind storm.
SteveH
Colo Springs
My exhaust guy welded exhaust systems for 30 years, and never disconnected a battery - and never fried a computer. His point was this: always put the ground clamp as near to the welding area as possible.
A church buddy also importantly pointed out that you never want to ground a weld through a bearing (whether on a lawn mower, axle, or whatever), as you can arc across the rollers in the bearing, and fry the bearing prematurely. With these tips in mind, I think you can safely weld body metal on your FJ40.
kurtnkegger
Denver Burbs
I finally drove it 10 miles to the LineX place for some tub liner. They are going to do the fender wells, and rear wheel wells too.
My Sister talking to the LineX guy....
simps80
Arvada, CO
Kurt,
if you don't mind sharing,
what is the approximate cost of the line-x work?
did you find a paint shop to pain it, if so mind sharing cost etc ?
also, what are the plans for the hardtop?
it's looking unreal, especially considering where you started! :thumb:
kurtnkegger
Denver Burbs
Mike, the LineX is going on the inside of the tub, including the footwells and sides. The fenders, and wheel wells and as much under the tub as they can reach for about $1200. It also includes the UV coat, which further seals the little micro-holes for better protection. The Rhino people wanted to start at about $1000, so figured the LineX got the whole thing done for what Rhino wanted to start.
I don't know who, or where the paint is going to be sprayed...costs etc...My Sister told me one paint guy she talked to could repair the fiberglass top before paint, but I was thinking the LineX place could shoot the top, inside and out (since they do colors) and seal the little holes...and still look pretty cool...I would suspect that would cost under $500 for that, but that's only my guess.
What surprised me about LineX, is there isn't a lift at their place to do an undercarriage, or no 90 degree spray tip for tight spaces. It should be ready for pick-up in about a week.
kurtnkegger
Denver Burbs
Well, well...
Line-X got done (months ago), and towed to the paint guy...there it sat, got paint, sat some more, got more paint...FINALLY got finished, and towed back to my place!!
There were a few items that weren't done right...back frame painted the tub color...instrument bezel, ash tray, glove box painted the same color as the tub...inside of the hardtop not painted...little stuff to correct...
The headlight bezel was upside down (quickly remedied)
New tires on painted wagon wheels (to match bezel and top)
Time to start getting the turn signals, brake lights, badges...The end is coming near! I'll post pics as I get stuff done.
