Have you ever been on a trip and checking the weather because you are concerned about an unexpected Freeze damaging your Sprinkler system? I had to come home from the Maze early a few years ago because the weather was going to turn unexpectedly.
Over the next few years I have some vacation plans that could be impacted by an unexpected cold front, but I will be too far away to do anything about it. My current plan is to have one of my son-in laws come over and take care of it.
For an unexpected freeze, I turn off the water in the house and run the sprinkler for a minute to the station at the lowest elevation. That clears out the above ground pipes and has worked well for me.
Two years ago I insulated the outside valve and wrapped the exposed copper with powered heat strip and insulation. Maybe I will do that again.
I found this device when doing a search
https://www.amazon.com/EcoNet-Contr...+valve&qid=1788094431&sprefix=,aps,257&sr=8-7
It has a wifi model and another model with Z-wave that requires a home hub. It seems like it would work on the inside house valve for the sprinkler and then I could run the sprinkller remotelly to drain the above ground pipes
I know a deep freeze could damage sprinkler heads. But, I am more concerned about the above ground valve and copper as an issue there would cause water to run indefentily.
Instead of just focusing on the sprinkler, some have installed a smart valve to the entire water system also using leak detectors to shut off the water in addition to having remote access. If nothing else, this has me thinking I should shut the main water off when leaving in the winter for an extended trip. Not really an option for early fall when you may need to run the sprinkler.
https://www.amazon.com/Moen-900-006...=d2lkZ2V0TmFtZT1zcF9zZWFyY2hfdGhlbWF0aWM&th=1
Obviously, the whole house valve provides much more capability and safety at an extra cost. Install is harder one the main line and if it fails closed, then that creates additional problems. I read some reviews that it sometimes detects leaks that are not there and shuts off the water when it shouldn't.
Anyone install either one of these? Thoughts?
I could use the heat strip/insulation method and my son-in-laws if its going to get real cold, but having more control is always a good thing . . . . . Right?
