I still have that entire 1fz for sale. It's from a 94 but i think the heads are the same.Quick update here.
- From the machine shop they suggested machinging both the main and rod journals...so I had to order the oversized bearing sets. Went toyota on those. Crank is serviceable otherwise.
- I had originally believed that I could buy a fully built head from toyota. However after more reasearch it now appears that the ~1500 head from Toyota is just the bare casting with some of the seals...no valves/springs/camshafts/etc. And the cams especially are crazy expensive. So..now I'm on the hunt to find a used good head and have it machined/worked/refreshed. I had hoped not to go this route because of timing and I'd bet the machine shop here has 0 stock of 1fz shims lying around.
- If someone has a known good head that hasn't been shaved and the engine didn't die of oil starvation...let me know
- I accidentally ordered two CHAIN DAMPER 13561-66010 when I got my parts at an extra $42....the part number is super close to the timing chain(13506-66010) of which I ended up with 0.
- If anyone is doing a rebuild and hasn't ordered their Chain Damper yet...I'll make you a super good deal (like just pay for shipping) because I ordered from Partsouq so not likely I can return it
Not really noNicely documented. Any liability or way to prove the filter caused the damage? With the cost of the rebuild might be worth looking into I would think.
Corey - this looks like it might be a good source for a head:
https://forum.ih8mud.com/threads/socal-1fze-engine-for-rebuilding.1208303/#post-13079595
forum.ih8mud.com
Well the 90915-YZZD4 are very inexpensive. Some folks on mud poo-poo them as they are a thai filter but honestly these engines are pretty easy on oil so not sure its a big deal. Personally like these filters. ~$4 on partsouqDamn! I’ve been running NAPA Golds for a while now w no issue. Done with that!
so what is best Toyota filter for the 80 now that the large one is NLA?
Thank you!
There is a thread in my Duramax diesel forum where a guy tore apart every filter made for that engine and the Baldwin filter came out on top for quality of construction, number of pleats, etc. I have often wondered if a Baldwin for the 80 would be the same?
I have also seen the yzzd3 discussed for LC. Is that also for the 80 or another year LC?
we've seen a lot of failures with baldwins on the heavy truck side. oil filters splitting down the side and fuel separators plugging up too quickly and causing issues. maybe they're geared more for the little vehicles though.Thank you!
