So I had a bit of an adventure heading back over monarch pass to crested butte last night.
In second gear headed up the pass, ~3600rpm, suddenly lose power and engine makes a pretty bad noise. Immediately get off the throttle and coast a bit....try throttle again and with anything other then very slight throttle, bad noise comes back. Hard to describe the noise...kind of like a loud, mid pitched groan or something. Pull off right after and take a peek at things.
-Engine Temp Normal/Coolant Level Normal
-Engine Oil level normal. No dash lights for oil level warning
-No dash warning lights at all.
-Removed Oil cap, and got a bit of smoke/vapor coming out. Not sure if normal or indicating burning oil. Have never opened the oil cap right after a hard pull at high RPM.
-No change in power steering effort. Have not messed with the crank bolt in probably 90k miles.
-Oil pressure on dash gauge not registering anything...which is typical for my cruiser that I have chalked up to bad sender in the past. Sometimes wiggling the wires on the sender gets the gauge to work. Sometimes it doesn't. This time it seemed the gauge wasn't even working...most times the needle is just very very low and doesn't move with engine RPM. Been that way where its just low for probably 60k miles or more. So didn't put any thought into the fact the needle wasn't even registering. Hasn't really registered in probably 500 miles or more.
At this point started it back up...tried to drive just a few feet forward up the road slowly and got the same bad engine noise. Conceded failure at this point and called a tow truck to get back to Crested Butte.
Dumped off tow truck by the house, was able to start it up and have a much louder clicking/ticking sound...but was able to back it into the driveway without the crazy loud engine noise...which kind of made sense as really no real throttle needed to back it into a flat spot. Idle is louder than it was but still runs.
So...now I'm headed down this path of did I actually lose oil pressure....either because of oil pump failure (which is extremely rare i gather) or because maybe the oil filter failed. Or maybe some completely other failure.
My plan to investigate:
-Pull spark plugs and just take a peek.
-Buy an oil pressure test gauge and see what that says. Any one have a recomendation on a good one to buy? Was thinking this one: https://www.amazon.com/OTC-Tools-56...re+test+gauge&qid=1555599747&s=gateway&sr=8-3
-Maybe pull the oil filter and put in a new one and see if the noise quiets down.
Anyone else have some suggestions on what to take a look at? At this point I have a feeling that there is damage done to the engine...just trying to figure out what and why to build a plan for repair/replace.
I'll try and grab a video of the loud idle.
Corey
Corey
