• RS MAY CLUB MEETING
Fiona, the blowed up 80 build
Looking great, i'm excited to see it running!!!
jps8460
Broomfield
Long overdue for an update! I’m hoping to hear it run this weekend. I’ve been fighting oil drenched connectors and some corrosion.
I’ve repinned, heatshrunk, re split loomed like the entire engine harness. I’d pay stupid money for a clean nice OBD1 harness lol.
Here are some samples of what I repinned and repaired.
Awesome I was literally wondering about this last night!!! Harness looks like it was annoying :/
LARGEONE
That sucks Jackson on the harness stuff. What a time suck!
ccslider
Looking good, I really like how you witnessed marked all your bolts. Good call and the "NO OIL", I've heard horror stories of people forgetting the oil on a first start after a build.
That oily harness just sucks!!
jps8460
Broomfield
This is a habit I formed at NASCAR Tech in our engines class. Our instructor was like Torque wrench (or stretch gauge) in one hand and oil pen in the other. Mark that bolt the second you get done torquing it.
jps8460
Broomfield
Fiona Lives!! Idle was just ECU relearning how not to stall. The check engine light is a lack of rear knock sensor communications between 1800 and 5200 rpm (code 55). Aside from that she purrs like a kitten, no leaks. Going to be a bit before I can deal with the knock sensor, but I’m pumped.
For startup, I pulled the ignition coil trigger wire and cranked until I had movement on the oil pressure gauge.
I heard this baby idle last night... just amazing, sounds brand new. So impressed! :bowdown:
jps8460
Broomfield
Aww shucks thanks Tim. By the way, I got drunk by accident..... how’d that happen?
jps8460
Broomfield
Figured out the CEL for the knock sensor. The used knock sensor I installed was bad. I installed another used one I had and it solved the problem.
The engine now has about 1.5 hrs of light load running, including a couple laps around the neighborhood.
Up next is to dump the break-in oil, change the filter.
Daniel @Inukshuk gave me a pro tip on a replacement PAIR valve hose. It used a Tacoma radiator hose. The fit is perfect! Thanks dude!! Toyota PN: 16572-07040
The hardware for installing the plug wire covers came is, so I got the covers installed.
I got the hood back on and installed some aftermarket struts. I’ve had the same one on my other 80 for about 2yrs now. They seem to be holding up well. They come in 2pc kit for left and right and include the brackets and hardware to replace everything including the ball stud. At time of writing, the kit is $39
Unfortunately my passenger side washer squirted isn’t working, but I’ll get that sorted out.
I’m hoping to get the new to me headlights installed tomorrow and put the grill back in.
jps8460
Broomfield
Ok so a long while back I bought these depo headlights thinking..... they’re for a RHD 80 so the pattern will be messed up, but that’s better than 2 busted shattered headlights and used ones are a bazillion dollars when you find them. (Still looking for a pair wink wink).
Well they have sort of a weird overseas variant of bulb and fit (h1 and h4) that require adapting, and the whole think seemed hokey.... so I made it even more homey... sort of.
My original headlights were in great shape minus the glass. So I decided to just swap glass. I got some butyl rubber heatedvthem up separated and swapped. Total with cleaning and install was about 3.5 hrs.
Haven’t road tested the pattern yet. It would be sweet to find just the glass some where, this was a $250 hack up.
jps8460
Broomfield
overall I I’m pleased. Going to rip it around this weekend and hopefully emissions test it next week.
Do you plan to bring this to CM?
jps8460
Broomfield
White Stripe
Milky way galaxy
Haven’t road tested the pattern yet. It would be sweet to find just the glass some where, this was a $250 hack up.View attachment 101902View attachment 101903View attachment 101904
I did projector retrofit to my depos. Personally I think it's one of the best things I ever did to my cruiser for night time visibility and I still have the high beam side for a driving light, fog light, or high beam.
jps8460
Broomfield
Oh emissions..
I was fighting a NOx issue, but nearly passing twice. I’ve also been logging a lean target A/F and short term fuel trim thing. So I made some adjustments and got pretty close.
One of my O2 sensors was really lazy, so I replaced both of them this morning after my test where I barely failed for NOx
When I returned to testing I failed miserably for everything lol. My target A/F is at 5.0V which means it’s over correcting for a lean condition. 🤪🤪
Going to drive it for a few days and see what shakes out.
Booooo hisssss. Everything else tests great and is in fine working condition.
SteveH
Colo Springs
Hmm - some E85 might help here, as with many 80 series owners.
jps8460
Broomfield
Possibly. That would lean it out. But I think I just need to hard reset short and long FT’s with new o2 sensors. The 93-94’s are always a pain to diagnose.
