DouglasVB
After a couple years of not having a Toyota, I'm back in the family with a 2022 Tacoma TRD Off-Road six speed manual that I picked up with 3100 miles on the odometer. This thread is to document what I'm doing to the truck over time. My current desires are to 1) keep it as a daily driver and 2) make it a massive rock crawler with desert capabilities. Yes, those desires are orthogonal 😅
The most immediate needs that I see are:
- Dash cam - Installed 12/28/2023
- Catalytic converter guards - Installed 3/3/2024
- Repair the two holes drilled into the front of the truck bed (looks like a previous owner project they never finished -- I need to paint the bare metal and then I'll find some rubber plugs to put into the holes) - Didn't need to fix them because it's a fiberglass bed 12/28/2023
- Tire chains (I think only for the rear?) - Purchased 12/24/2023
The truck currently has the following accessories from the prior owner:
- Dark tint all the way around - removed the front tint 2/2/2024 (roughly) and probably will remove the rear tint eventually
- Body Armor 4x4 HiLine Front Winch Bumper
- Two row LED light bar installed in the front bumper
- TRD skid plate - removed and replaced with an RCI skid plate system 1/6/2024
- Bed mat
- Tri-fold hard bed cover
- Side-step running boards - removed for RCI sliders and then installed RCI sliders on 4/28/2024
- WeatherTech floor mats - replaced the rear mat that was cut up for a gun safe 3/3/2024
In the intermediate term, I'm looking at doing:
- A/C hose drain extension - done 12/29/2023
- U-bolt flip kit
- Skid plates for all of the sensitive bits underneath - mostly done as of 3/3/2024 and finished as of 3/31/2024
- Armor for the A-arms and such - done 1/6/2024 including gas tank skid
- Sliders - installed 4/28/2024
- Winch - installed 5/12/2024
- Either get the high clearance side wings for the current bumper or get a new front bumper
- Rear bumper
- Bed stiffeners (I think that's still a needed thing on the newer 3rd gens?) - installed as of 3/31/2024
- Bed topper/camper shell (not exactly sure which I want yet)
- Amateur radio (might use my old Yaesu FT-2900 or might upgrade to something that does 70cm and maybe some other bands as well. Also I want APRS.)
- GMRS radio
- CB radio (I just can't give it up!)
- Hidden kill switch
- Front-facing camera wired into the infotainment unit (seems like there are a lot of different versions of this but here's one) and it would be cool to have the 360 camera mode
Longer term, I'm interested in:
- Long travel that preserves ABS and other safety features and new shocks etc
- Bigger tires / trim things to make them fit
- Re-gear
- Front locker or similar
- Dual t-case setup or similar
- More armor especially to protect the quarter panels and such
- Brush guards inspired by @HoneyBadger 's brush guards 😂
- Maybe flatbed the truck and have a camper that can be loaded on and off easily like this?
- Tube doors
Other stuff that I've done:
- Installed a full-time 400w inverter kit with 120v plug in the cab - 4/27/2024
We'll see how far I get down these lists 😅😅😅
Any suggestions, thoughts, input is greatly appreciated!
