Chain Saws
DanS
Dumont
Yeah, that pic is actually white oak, we get it often! How many beams do you need?
I want to say Norwood can mill 20' lengths and up to 36 inch diameter if you're careful with your first cuts. I like it, but its the only mill i've run, so nothing to compare to.
Off the top of my head, 10. Easy.
These are for long term historic railcar preservation projects, so not looking for perfect grain, or anything more than white oak that I can mill down to size.
I'll send you a text message, if not now, when I get back to the US tomorrow.
Dan
Has anyone tried out one of these harbor freight electric chainsaws?
cbmontgo
Divide, Colorado
Once I adjusted my CS-590 for altitude and ported the carb a bit, I have really enjoyed using it. My friends that have borrowed it can't believe how well it runs for a HD purchased saw.
I've had an Echo CS-400 since around 2008 for smaller jobs and it's been crazy reliable. Use my Stihl for the bigger stuff, but it has been more of a maintenance hog comparatively. Both are great saws though of course.
allen.wrench
Syracuse, UT
Seems like a good saw for reasonable price. If I had to buy one, I can see myself getting a cs590.
Allen
My mantra, when living in Summit Co. in the ‘70s and early ‘80s, was if you hadn’t started your firewood gathering by the Fourth of July you were running behind. Chainsaw and a 16lb. maul were all I had to use. Our cabin’s fireplace opening was 6’x3.5’x3.5’ so a big bunch of wood would fit in it. Good times.
Winter arrives much sooner in Summit. My goal is generally to have it cut/split/stacked before Elk rifle opens.
We lived in Frisco at the base of Mt. Royal. 102 Pitkin St. December, January and February the sun went behind the mountain at 1:30 pm. Made for long and dark winters. Could have bought it for $45k in 1984 but passed. Eleven years of that kind of cold was enough.
Do you need to season firewood out here? One summer back east wasn't enough to get a good season on it if it was live when cut. Anything fallen would usually be rotting and worthless before it would ever be dry enough to burn. I used to seek the widow makers to heat my house after the seasoned wood would run out in the winter.
That’s a lot of work @Corbet!
Our standing dead trees can be dryer than kiln dried wood you buy at Home Depot! :)Doesn’t take long.
I will have about 40 more ponderosa pines (with mistletoe) that have to be cut this fall to stay up with my forest management plan.
This tree is ready to go once divided into very small fractional pieces. Probably been standing dead for a decade. Really clean as far as knots. It’s going to split real nice.
Thats an M101a1 right? did you do anything to beef up the leaf springs on it for that load?
Yes 101a1. It’s got a set of Timbrens, they made a huge difference. I used it in this fashion for many years without. The axle would sit on the bumpstops, then I lost a bump and the spring would invert. That is when I did the upgrade. My next upgrade will be to swap out the axle for one with brakes and a hub that will fit a 6-bolt Toyota wheel so that I could run he trucks spare in the even of a flat.
