Well, after weeks of waiting on parts and lots of wrenching, it seems the stout is in a "two steps forward, three steps back" mode. I got all of the wiring replaced for the alternator and new VR. Re flushed the "new" radiator and added new water pump, gaskets, hoses, etc.
Fired it up to test charging system and it fired up but charge light stays on and there's no difference in battery voltage (off) vs alternator while running... guess my wiring job is messed up.
Pulled it out of garage and now parking brake cable is seized up... and one of the newly rebuilt wheel cylinders is leaking...
Filled with coolant and tried to burp it and no air is escaping and immediately overheats, just as it did before all the waterpump work...![BangHead :banghead: :banghead:](http://www.risingsun4x4club.org/forum2/images/smilies/banghead.gif)
I flushed this new radiator 2 times, but perhaps it's just blocked solid it also is not identical to my oem unit. It didn't overheat prior to the radiator swap, so that's where I'm guessing the issue is. Bummer as I spent a ridiculous amount to buy and ship this crap radiator.
Anyway, after weeks of work and parts, no progress. 😒
Stout is getting put into storage. Maybe it will be there another decade like before 😝
Need to get the 60 out which is ready for some maintenance and the 40 needs a new manifold gasket...
Adios folks!
![i-GzNHPg9-L.jpg](https://photos.smugmug.com/photos/i-GzNHPg9/0/1a039424/L/i-GzNHPg9-L.jpg)
Adios folks!
