KC Masterpiece
- Joined
- May 4, 2019
- Messages
- 2,034
My shop is next to a diesel emissions testing place and yeah - some of the trucks smoke the place out!Meanwhile at the diesel testing center.
Skipping leg day?Who can guess what I'm doing today?
Explain to me how this works. I might need to know it someday. I assume putting smaller tires on helps you pass emissions?Who can guess what I'm doing today?
The emissions testing centers here locally in the Denver metro will sometimes let you test with 315's or 35" tires and some others won't. I have had success testing with 315s at the Sheridan station but not at the Northglenn, Dacono or Ft Collins stations. So with that being said I bought a set of rollers to swap out my 315s so that way I don't have to worry about being turned away right before I am about to test.Explain to me how this works. I might need to know it someday. I assume putting smaller tires on helps you pass emissions?
I suspected the less stress part but not the actual tire size getting you turned away. Do some of them just not have dynos that can fit that?The emissions testing centers here locally in the Denver metro will sometimes let you test with 315's or 35" tires and some others won't. I have had success testing with 315s at the Sheridan station but not at the Northglenn, Dacono or Ft Collins stations. So with that being said I bought a set of rollers to swap out my 315s so that way I don't have to worry about being turned away right before I am about to test.
And yes they can potentially help lower your emissions by reducing the stress your engine is under trying to turn the larger tires.
That's the gist of it, there's a limit for the regular dynos and some are more willing to do it than others. There's usually never any question at 33" tires, though larger than that can be hit or miss. Sometimes they won't do 34" either.I suspected the less stress part but not the actual tire size getting you turned away. Do some of them just not have dynos that can fit that?
Now I'm just imaging same crazy lifted jeep running 40s having to swap to some piddly stock tires to do emissions, that would be a sight lol.That's the gist of it, there's a limit for the regular dynos and some are more willing to do it than others. There's usually never any question at 33" tires, though larger than that can be hit or miss. Sometimes they won't do 34" either.
Update:Replaced three hoses, six clamps and a clutch slave cylinder and only needed a 12mm, 14mm, 17mm and 1/4" drive.....gotta love the old rigs!
You know that old saying of "if it an't broke, don't fix it"? Well, I took the Pig up to get gas and check for leaks and noticed a little stumble in the idle and at low speed. So, I got back home and cleaned the carb and checked the cap, rotor and points. Noticed there was rust on the rotor and carbon buildup on the cap and points. Cleaned it all up with some light emery cloth and boom.......won't start and no spark from the plug wires. Damn.....must have messed up the rotor and points with the emery cloth. And, of course no one carries a points set in stock any more so I'll have to wait till Tuesday for them to get delivered.....grrrrr
Could your coil be bad? Not sure what about the dizzy would cause that with all the new parts. Unless the cams are all worn down. Bad coils are rare but I’ve seen them, and man are they hard to diagnose. Swap one in from another rig?Update:
After learning that at some point in the last 53 years some one added a Delco Remy Distributor into the Pig I've spent hours sourcing points, condenser, rotor and cap for a distributor that was originally meant for a 1959-1962 Chevrolet in-line six!
I then spent 16 hours putting in new plugs, wires, points, condenser, rotor, cap, coil and cleaning all the contacts and while I get 15 volts to the dizzy and a weak spark at the points, I'm not not getting any spark at the plugs. Researched MUD for hours and it appears this old Delco Remy Dizzy has crapped out. Looks like I'll need to source a OEM F motor dizzy! What a PITA since it was running fine and then just stopped! I guess I should be glad this Delco Dizzy didn't grenade in the engine like some have.
Same here. I've tried a new coil with no effect. I've cleaned all the positive and negative connections and replaced a wire into the wiring harness that had some bad insulation with no effect. The Delco dizzy is a piece, the points small adjusting cam screw next to the locking screw has snapped off, so while I can still adjust the points and lock them down I'm losing confidence in the whole distributor.I suppose worn shaft bushings could cause the dizzy to take a poop, but not like a step change. Check the coil and all wires for continuity and possible poor or inadvertent grounding.
What roof rack is that?? Me need it!!!Who can guess what I'm doing today?
