Huzzah! Back together (save some non-critical bits) and running/driving/stopping!
I drove it about 3-4 miles total from my house to the gas station and back. This would have been a good time for a photo, save that I didn't bring my phone with me (there's usually no point since there's no service up here)...
New to do list:
-I can't seem to get it out of 4 wheel drive. It shifted in and out when I started fooling around with it this afternoon, but won't shift out. Goes from 4 high to 4 low without any trouble...
Not sure what might be the issue here save some linkage adjustment...
-Did not want to get warm. I know it's cold and all (and the cold weather intake was set accordingly), but I couldn't get it above the lowest tick in the normal range on the temp gauge, and couldn't get it to run without the choke about halfway. Higher RPM resulted in lower temp... I hoping it's just the tune and not the thermostat... That would be my luck.
-No guts. Could not go up my driveway (which is admittedly VERY steep) save in 4 low. After this, I set the timing (was set per the book by PO, now advanced from that 3-4 degrees), which will undoubtedly help.
-Further lack of guts. Once in 3rd, it would not accelerate. Timing accounts for some of this, but the rest is no doubt the poor jetting.
-Brakes pull to the right. Just need to adjust them... Too bad I don't have any solid ground to jack the bastard up on... I'll have to go on a rock hunt for one that's big/flat enough... In the snow...
-I was messing with the radio while it was warming up, and the tuning knob seems to be messed up somehow... It worked, then let go, then worked a little more, then did nothing again... I gave up without really putting up much of a fight. I'm not much of a radio person anyway.
-Shortly after I got it going, the choke refused to be pushed back in... I came inside and did a quick search on Mud and found the solution (it was pulled past the catch spring, I reached up underneath and poked it up with my finger while pushing it in with the other hand). Choke is again functional.
-Valve adjustment. I was planning to do this after setting the timing, but between not having a replacement gasket, not being sure the best way to advance the valve train with the engine off (I prefer to adjust valves with the engine off to save wear on my feeler gauges), and just running out of time, this will have to wait until I get back from family visitation...
-Distributor seems to wobble a bit... Not sure what to make of that. I don't like it, but I don't know that it's not normal or that there's anything that can be done. Would anyone care to offer some insight?
