Tacoma Failure
jps8460
I picked up my Tacoma and there were all kinds of error codes before I even drove away. P0705 which is the Range sensor code or Neutral Saftey switch which is what they just replaced. They had me leave it again because they couldnt get to it today :(
My guess it isnt installed correctly or it needed to be calibrated. They should have verified it before they gave it to me.
I read another owner has a similar problem and their dealer in Florida escalated it to Toyota Technical team even though they couldn't reproduce the failure. They first replaced the battery under warranty and then the starter when it failed again. Looks like it has been working since that was posted a year ago. I brought that up to my Dealer (Autonation) who said we don't do that unless we have a failure.
He told me the Tech said I should drive it more as that is probaly the issue due to low miles I have on the truck. That makes no sense.
Likely will also replace the Starter and would rather not do that on my own dime
Does anyone have a contact at Toyota with an email I can reach out to on this issue? So far I have spent over $500 on replacing the battery and the Neutral Safety switch because of this failure that has left me stranded twice on a vehicle still under warranty
@bvb @jps8460 @cruiseroutfit ?
So sorry to hear your having these issues. The Toyota dealership experiences can be hit or miss. Since they are decoupled from corporate, the first thing I’d try is going to another dealer. I personally have not had a recommendable experience with any of the front range dealerships I’ve used. That includes Stevinson West, Mountain States, and Lexus of Greenwood Village.
I have had very good experiences with Western Slope and Montrose.
I unfortunately don’t have a contact that would be helpful in this situation as we don’t work with these departments.
Centennial, Colorado
Thanks Jackson
Here is a summary of my issue (most is a repeat). Trying to get my documentation all lined up
This failure has occurred twice, first in Dec 19, 2025 and again on Sept 23rd 2026. What happens both times after driving someplace for 20 minutes and coming back to the truck after an hour, the truck does not start. Everything comes on, but there is no crank to the starter, no dash error codes and nothing else amiss except no crank, no clicking, no sound at all I can tell from the starter. I tried starting it with a NOCO Battery and no joy
In Dec, after 3 hours of trying to start, it suddenly started right up with no issues
I ran tests at home:
  • Alternator voltage is good
  • Battery Voltage was 12.6V
  • No error codes
I read some of the new Panasonic Batteries had bad intermittent cells which could have caused this
On Dec 20,2025 I took it to the dealer and they couldn’t find anything wrong. Battery tested fine. I know sometimes a bad intermittent cell will test fine, so I had them replace the battery at my expense. I needed to do something so I wouldn’t be stranded. I thought that had fixed the issue
Failed again on 9/22/2026
I drove 20 miles to take my wife for her cancer treatment. Afterwards we tried to leave at 11AM and the truck wouldn’t start. I checked the Battery cables (Tight), I checked the voltage (12.6V), I tried to jump it with my NOCO Battery Booster and no joy
  • No codes
  • No error lights
  • Everything else worked
  • It recognized the key FOB
  • It said “press brake pedal and press start” and when I did that, the message went away
  • I could see the Brake lights come on, so it would not be the Brake Sensor switch that enables the start
I called AAA and they came out to test and try to jump the battery. They said the battery was good and jumping did not do anything. At this point I sent my wife home in an Uber
Since I was on the 2nd floor of a Parking Garage with low clearance, I was told it would be a 6 hour wait for a tow truck. I tried to start it at least twice an hour
The Tow truck driver came and said he couldn’t get into the garage due to clearance. So I used my winch to pull/push the Tacoma down two levels of the garage to where to tow truck driver could get me. I had the truck “On” (no engine) to use the brakes. This discharged the battery, it was fine before when AAA did a Battery test. The battery was not discharged until I had to use the winch.
The Tow truck driver took me to AutoNation Toyota and I verified it was still failing.
When the dealer looked at it the next morning, it started right up and they could not recreate the failure
The tech sent me a video saying I was concerned about the battery and it was discharged but still good. I am not concerned about the battery and I explained using the winch is why it was discharged. They failed to include that in the service write-up as to why the battery was low even though I asked them to.
Reading through the factory service manuals I see the following potential causes defined by Toyota:
  • Starter Relay
  • Starter (likely solenoid)
  • Neutral Safety Switch. I did find a few videos saying this is a problem on some of the newer trucks
The dealer was not able to recreate it. I understand being an engineer its extremely difficult to troubleshoot something that isn't failing. The technician thought it was the low battery, but that is due to winching to get myself out of the parking garage
I had asked them to contact Toyota Technical support to help resolve this issue and they said they wouldn’t do that unless there was a failure.
I don’t want to get stranded a 3rd time, so I asked them what it would cost to replace the Neutral Safety switch and the starter. They wanted $750 for the starter install and said the part was $360. Toyota list is $249 and I can order it online from that same dealer and pick it up for $249, but it costs $360 through service and if I walk up to the parts counter??
I asked them to replace the Neutral Safety switch and I would look at other places to do the Starter.
I came to pickup the truck on 9/25/2026 and when I got in lots of dash lights came on with a error message to see dealer engine operation issue. The Service advisor ran a code reader and came up with P0705, which is a transmission range sensor circuit malfunction, typically due a problem with the Neutral safety switch. That is the part they replaced and likely an issue with the install.
DanInDenver
I’d suggest going broader with your story. Mud, Facebook and Reddit. You have a well documented and rational approach to the analysis of the issue. Maybe a little press will get the attention of Toyota. May also help with crowd sourcing the solution.
With Ai searches it’s much easier to find things now.
Good suggestion Dan. I will see what they come up with in the morning before posting
My truck was ready. Apparently the first technician didn't adjust the new switch. He sent a video saying everything was good with the switch that was installed BY A DIFFERENT TECHNICIAN :)
My faith in Toyota is restored I called the Brand Engagement number and they sent authorization to the dealer to replace the starter and reimburse me for the Neutral Safety Switch and Battery
They said the dealer should have this by Monday and to expect a call from them
RayRay27
RS Club TLCA Delegate
Thornton via Boulder
Call Toyota Brand Engagement 800-331-4331. It's a long arduous process. Ive had to do it several times with my Tundra. Just file a case and tell them all your issues. They may contact the dealership directly and ask what the problems are. They may also tell you just to keep taking it to the dealership like they did to me. Hopefully you get a better response then I did.
thanks Ray- Read the post above yours :)
I was very enouraged by the people who answer the phones at the Customer Engagement group. They said Toyota will take care of it. The Dealer got the email from them and called me Saturday. They said they didn't know what to do with what Brand Engagement had sent them since they can't authorize warranty work.
I called Toyota Brand Engagement back and they escalated it to a Case Manager
The case manager called me today and said without any diagnostics to show what is wrong, they didnt think they could authorize any work. They said they would contact the dealer and other stakeholders and get back with me by the end of the week
Calling Toyota Corp was the right thing to do. Much greater chance of it getting handled. The independent dealership hates to receive calls from the Corp office about unhappy customers. But at the end of the day if it does not present its self during diagnosis, the path to resolving it is going to be tough. No body is going want to simply throw parts at it. The squeaky gear gets the grease. So keep complaining.
IoN6
I would absolutely be slipping in comments about lemon law with any and all parties. It is a shit process, but I bet it is a shit process for them too.
lets assume for a moment they come back and say they have to see it in a failed state. I see my options:
1) Wait until it fails again leaving me stuck someplace. That is going to effect how I drive it, where I park (no more garages) and when I would leave it at home due to the risk of getting stuck
2) I already replaced the Battery and just now the Nuetral Safety Switch on my own. I could also replace the starter and starter relay
3) Sell it or trade it in
Option 1 is a non starter (pun intended) for me even though I may have fixed it with the Neutral Saftey Switch. My best guess is the starter based on the way it behaves. I think by disconnecting the battery for a while I reset the ECUs which should have eliminated any SW interlocks?
Option 2 is where I am leaning and I hope it gets done under warranty, but think this is the bare minimum to have sense of confidence in having fixed it. Not saying 100%, but thinking at least 75% with the Neutral Safety Switch and SDtarter relay. Though I could just carry the relay and swap it out if it fails
Option 3 is what I would consider the last resort if I expend all reasonable avenues to resolve this and it fails again
The probable causes I found are:
  • Brake sensor switch - I don't think this is it because I can see the brake lights and the message "press barke and select start button" changes when I do that even though the truck doesn't start
  • Immobilizer - Thinking reseting the ECUs should have addressed this? I also think this would set a code
  • Other SW interlocks- Thinking reseting the ECUs should have addressed this? I also think this would set a code
  • Battery - checked out, replaced after first time and new one tested fine and a jump did not change anything
  • FOB Battery- The truck recognized the FOB and I held it up to the start button just in case ( I will now carry a spare battery just in case)
  • Nuetral Safety Switch- Possible
  • Starter Relay- Fails to close and engage the starter
  • Starter - Fails to turn over
The two times it has failed, it has done so after a 20 minute drive so it was warmed up. Then it healed itself. The 2nd time it cooled down and quite a bit of truck movement with the tow and then movement into the highbay. That makes me think it is mechanical in nature and why I am thinking Starter/Starter relay or possibly the Neutral Safety Switch
Thoughts?
zgfiredude
Silt, CO
I follow your logic path, and would tend to agree with all of your theories. I might carry the starter relay with you, and if it happens again, do that swap so that you'll know IF that fixed the issue. Otherwise you are just guessing/hoping that it did. Video any symptoms and what you might do in the field to resolve. This may have to serve as your proof of failure as it doesn't throw a code, and it self heals before the "brain trust" :ROFLMAO: at the dealer get to see it.
can you simulate the issue by not having the truck in neutral and trying to start it? Does it behave just like it did when it had the issue? I ask because it seems to me like a neutral safety switch not working wouldn't let it say hold brake to start, then allow it to behave like its starting with the lights etc. but just have no crank (turnover). That's kind of making me think it might be a starter (or some part of that system) issue... in which case you may have not solved anything with the battery/switch change. So... FWIW.. maybe leaving it as is I'd expect another no start situation to pop up.
@Romer I think you're more than equipped to figure this out. Assuming it's the neutral switch or starter is about all you can do.
I'll just say that when the immobilizer in the Jetta locked up the only right way to fix it was to take it to a dealer who had dedicated application and cable necessarily to unlock it. <removed for privacy>
In your case even if it was dealer-only sort of fix there would be diagnostic events recorded so even if the dash didn't display errors the dealer would have seen them one assumes. So all of this is likely not your problem. Anyway, unless the controller is completely in the weeds the bypass using the push this pedal, push that button some number of times should let it at least crank.
Still, you'll appreciate this article. While I think things are tighter now I would also not assume automobile engineers are nearly as diligent about fault tolerance, fault recovery and systems testing like you're used to in aerospace. There is a lot of crappy code and a whole lot of legacy code in all these ECUs, which your truck probably has around 100 ECUs. All it takes is a bug in the ECU that controls some random thing to upset and no one's testing all the corners on these things.
https://spectrum.ieee.org/software-eating-car
I also wouldn't assume you'll never have non-reproducible anomalies or that every one of will be fully trapped and stored either. A long time ago hackers figured out that the TPMS sensors were unprotected modems with direct access to the main ECU, so that was a gateway for years and still is. Tesla still had this vulnerability in 2024, for example.
https://www.synacktiv.com/sites/def..._tesla_model_3_through_tpms_sensors_light.pdf
The whole situation is inconceivable to me. How so much potentially faulty code could be sent into the wild would have me as a cognizant engineer or PM pulling my hair out. What's left of it.
Thanks. I do plan to document with video any more annomolies. The dealer won't accept anything iof they can't replicate it so it is more to build a case.
If I am unsucccesful with Toyota, I will replace the Starter and get a Starter relay and carry it in the glove box. The strater itself isnt to expensive if you buy online from a dealer. I just crawled under the vehicle with the printed FSM Starter replacement instructions. It looks tight going through the passenger wheel well, but doable
Tanks Marco, normally the vehicle is in Park (Automatic) when trying to start it. I tried Park and Reverse when it was faling and it would not start. The switch was a lower probability, but also more difficult to swap myself, while at the same time the cheaper option from the dealer.
I am working though a "worst case changeout" which on the things I am use to working on (Spacecraft) you work through and replace all the potential causes if you get a failure that goes away. Even then, it doesn't prove you have fixed it so the spacecraft may never fly, but easier to do with a Tacoma since you can call a tow truck.
That is what I thought. Thanks for the articles and sharing your story
Appreciate you guys. It is always helpful to bounce things off others
If you put it in reverse and try to start it does it behave the same as it did when it was failing?
It does Except I get a message to put it in Park to start. This is with the new switch
