Lawn tractor help
Land Use Coordinator
Ok any small engine experts out there?
I have a John deere d105. No idea how old, bought it used a few years ago. Always ran good, less then 85 hours on it. Ran twice this spring, no issues. Last week my dad was using it and he backed up and forgot to turn the blades off and it died and wouldn't start again. Just clicked. I have now replaced the battery, starter, and starter solenoid. Still just clicks. Even when I connect the 2 terminals on the starter solenoid it just clicks and no spark when I try and start it. Old starter bench tests fine.
I'm at a loss. I notice that even with the key off, the positive cable from the battery to the solenoid has power and when I connect the 2 solenoid terminals then, it does spark and I hear a slight whirring that might be the starter but obviously the spindle is not raising to engage the flywheel. But when I jumper those 2 together and try to start it, just click and no spark.
Any ideas? Thanks!
BritKLR
Vice Commander
ATC HQ - Nederland, Colo.
Sounds like one of the safeties got tripped and won't let it restart. You'll need to do some googling on that particular model to determine how many it has and which one maybe the issue.
1) Check and see if it has a back-up blade disconnect button on the dash to shut off the blade when backing up. Sometimes simply pressing it several times will get it restarted. You can also by pass it with a jumper wire.
2) Check the seat safety. Lift, drop, adjust the seat to see if the seat safety got mis adjusted as he turned around to back up. Sometimes you can fiddle with it to get it started but since it is pressure activated you will need to be in the seat.
3) The mower deck will have several safeties that must all be aligned and working properly otherwise it wont't start.
4) Some of the controls have safeties on them and you need to firmly reset each one make sure they are in their proper startup position.
5) The most PITA safety on mine is the brake safety. It's under the deck and will sometimes decide to just not work (dirt, grim and grass clippings) and it'll take me an hour to pull the deck and brake clean the hell out of it and then have to reassemble everything before I can test it. I really need to just jump it one day.
Sometimes several safeties will get out of alignment and they all have to be checked, cleaned and fiddled with for the mower to start.
Good luck!
Thanks. Usually when it is a safety switch issue, it doesn't even click. For example, if I leave the brake off, it doesn't do anything at all when I turn the key. Once I put the brake on and engage that safety switch, then it will click when I try to start it.
Done. Was the negative battery wire to the frame. Thought for sure that was one of the first things I tested. Shrug. Thanks to all for your help and have a great memorial day weekend
