snow chains for plow truck?
gr8fulabe
Boulder Canyon
Hey All,
Can anyone possibly advise which of these would be better suited for plow work? Dirt/gravel road, 3/4 ton Dodge (the orange sno-fiter I picked up a while back for those that remember). I'm toying with going to a 16" wheel instead of the 16.5, so I'm thinking of only buying chains for the rear right now to save money since I'd go with a bigger tire on the new set. Thoughts? Are they basically interchangable, or is one way better than the other for the purpose?
Thanks a bunch!
On the RX
Superior
The cheaper v-bar chains will be better on pack ice and less prone to sliding sideways. They are more likely to break under the load of pushing snow.
The twist link will last longer and will be better at handling the shock load of plowing and will not be as damaging to concrete and asphalt.
SteveH
Colo Springs
When plowing heavy snow at an angle, the plow will want to push the front of the truck sideways. You may find that front chains (or all 4) are the way to go. After getting my plow truck stuck a number of times, I put chains on all 4, and it's mostly unstoppable. But, I only plow on dirt - never on pavement.
DouglasVB
My old 4runner had boron square link chains that were extremely good in snow and ice. Can't comment on how good they'll be for a plow with significant front end side loading. But on a built 1st gen 4runner they worked miracles.
