forum.ih8mud.com
You are correct. The solenoid is fine. And after checking more, it is actually idling off the idle circuit. When I look down into the carb, there is no fuel coming from anywhere that you can see. And the pump works as it should.It’s probably not the solenoid if it’s running. But your carb must be getting fuel from somewhere besides your idle circuit if adjusting the idle circuit does nothing. Can you pop the air cleaner off and look down the throat of the carb and see if fuel is dribbling from the top somewhere?
... In the meantime, I fixed my backward working Temperature Gauge, so my original temp gauge in the cluster works perfectly now. I also changed my thermostat while I had the coolant out of the head. The truck just wasn't warming very quickly, so I thought maybe the Tstat was stuck open? NO change. Oh, well. ...
I do this as well...mostly because I can (with the custom heat valve I made)If you're not needing the heaters, closing the heat valve on the firewall will get the engine temp up quicker since you're not cycling the coolant through the heater cores. Mine is seized open. As soon as it warms up here i`ll start going through the cooling system.
Keep it up, I'm enjoying your progress!
Yeah, mine needs replacement anyway. Some kind of aftermarket unit on there and they changed out the flair fitting to match so I get to replace the hard line too. Brakes work except for parking brake, so its low on priority list.meh dual circuit brakes are for schmucks
