Capriblue45
- Joined
- May 28, 2023
- Messages
- 586
I would replace both the pilot and throwout while you have the trans out. Not a job you want to do twice for such a minor cost.
The new pilot I got in a kit from Kurt is loose on the input shaft of the original, but snug on the shaft of the spare so I guess I'll swap it.I would clean up the shaft with some emory paper and make it smooth and slide the pilot on and see how it it fits. As you know the shaft should spin the pilot bearing. It looks like yours spun on the input shaft until it locked on the bearing.
mad skills. Way more impressive than what I have been doing in the garage![]()
No question from your video. That's either pilot or throwout bearing (those only spin with the clutch pedal depressed). And you said the throwout was good, and that wear sure says it's a pilot bearing.
Dan
use the bread method. it'll push it easy.
The covers and half the ball bearings fell out, so I don't think the bread trick will work.Was gonna suggest bread also
the rest should come out in pieces I bet. Nope. The bread will work. You want soft bunny bread. It'll take 3 pieces with a mangled pilot bearing, but when you get it out, it will be clean as a whistle in there.The covers and half the ball bearings fell out, so I don't think the bread trick will work.the rest should come out in pieces I bet.
