BritKLR
Vice Commander
So, I began noticing this earlier this year. Start the 60 and the in dash/original volt meter shows like 11 volts and after maybe 20 minutes it'll get to just below the 12 volt but never seems to jump to the 14 volt level like it use to to charge the batteries and then settle down to around 12 volts.
The 60 does run dual batteries and a dual battery charging system. I don't drive it a lot so it sits on a NoCo dual battery charging system...unless I forget...but otherwise it seems like a healthy system.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
