I picked up a new set of Wildpeaks from FBM yesterday for a great price to replace the 285’s with 315’s on my 97 factory rims. The original lift I bought a couple years ago was Dobinson springs only kit for 2.5” lift. The rear springs ended up providing more like 4” lift so I installed a set of rear ICON springs to level the truck. It had enormous stick bug prior to switching the rears out (see pic). I’m going to reinstall the Dobinsons rear springs now that I’ll be running 35’s. I have factory bumpers, Slee sliders, and a RTT. I don’t carry a ton of weight in the cargo either.
The question is what spring would you run on the front knowing the rear will have about 4”of lift? I like a level truck with only a slight amount of rake.
Another question is shock recommendation. I’m currently running a used set OME’s and the ride is stiff to say the least.
