80 series front springs recommendations
Telly
Monument
I picked up a new set of Wildpeaks from FBM yesterday for a great price to replace the 285’s with 315’s on my 97 factory rims. The original lift I bought a couple years ago was Dobinson springs only kit for 2.5” lift. The rear springs ended up providing more like 4” lift so I installed a set of rear ICON springs to level the truck. It had enormous stick bug prior to switching the rears out (see pic). I’m going to reinstall the Dobinsons rear springs now that I’ll be running 35’s. I have factory bumpers, Slee sliders, and a RTT. I don’t carry a ton of weight in the cargo either.
The question is what spring would you run on the front knowing the rear will have about 4”of lift? I like a level truck with only a slight amount of rake.
Another question is shock recommendation. I’m currently running a used set OME’s and the ride is stiff to say the least.
Hey Doug, I have been liking the offerings from Dobinsons. Unfortunately I don’t know exactly what front spring you need because of some strange variables. I believe your experience with the rear springs is a common issue. I have heard people wanting a 3 inch lift being disappointed because they end up with 4 inches of lift. I have heard this complaint with the variable tapered or flexi springs. You are in a unique position by wanting 4 inches of lift and having stock bumpers.
According to the numbers the Dobinsons C59-308 4.0″ Lift 110-160LBS Load seems to be the closest.
I’m not seeing an option for 4” spring for stock weight.
Knowing that you experienced an issue with the rear springs, I would suggest looking at a 3 or 3.5 inch spring.
The C59-176 3.0″ Lift with 110LBS Load could work.
That’s all I got. If you give me your rear measurements (center hub to fender) I can measure a few of the trucks at the shop that are running dobinsons springs and try to find something that would be a good match.
Telly
Monument
I like the suggestion…thanks!
Are you wanting that 4” of lift? The dobinsons seem to be a heavy spring which is why it sat so high.
What about keeping the icon rear springs and getting icon fronts? You’re relatively light weight and won’t be too much for the icon springs even with a front bumper/winch.
I only suggest this because I do have the icon front/rear springs and shocks. The ride and capabilities are great. I’m on 315/70/17 mud terrains as well.
Telly
Monument
Something to consider for sure. Likely I’ll be adding a rear bumper with a tire carrier sometime in the future. The Dobinsons might drop down to more like 3” with some weight. I dragged my butt over just about everything on Poison Spider and HR at CM last year.
Years ago, I had a built 97 FZJ80 with 4”Frankie’s progressive springs. Those spring road like a caddy with crazy flex. Too bad the company is no longer in business.
One option might be some simple spacers in front...
I think you can find them in 10mm, 20mm, maybe even stack 'em not sure. it's a cheap way to level things out... back in the day I ran this for a while (OME 850 springs) until I later ran 850j, then later Slee 4".
Telly
Monument
Thanks Tim. I’m currently running OME 10mm spacers on the Dobinsons front springs now. I plan to reuse if necessary. I’m going to research Scott’s suggestion of the C59-176 Dobinsons.
I am running the Dobinson's 2.5 variables. In reality I got about 3" of lift and the rear sits just slightly high unloaded. When loaded the rear sits a bit low, and I have the OEM 10mm spacer that I want to add too the rear one day. I have a 4x4 labs in the rear with a Dobinson's drawer set.
The Dobinsons variables flex really good on the front end.
Telly
Monument
Icon has a 3” dual rate front springs that look interesting. I’m posting from my phone and I’m a tech dummy because the link to the springs didn’t work. Maybe keep the Icons in the rear and go with these like @Lastresort576 suggested. So many options! Thanks for all the great suggestions.
Yup those are the ones I have along with the matching stage-1 shocks, delta 3” panhard riser bracket, and landtank caster plates up front with oem radius bushings.
FZJ Dave
I have the Dobinson tapered coils (varible rate springs) with 3.5" in front and 3" in the rear. I run 37's for reference. I have OME BP51's for shocks. I LOVE the way my 80 rides with this setup. If you know what the numbers are on the rears you have, you can call Cruiser Outfitters and pair fronts to what you have in 1/2" higher lift to level the truck for your weight.
The BP51's aren't cheap shocks, but they are freaking amazing. I seriously can't reccomend calling Cruiser Outfitters enough. They know their stuff and can help you order exactly what you need to get your rig setup for what your end goal is without you having to piece meal together some stuff.
Telly
Monument
Had to look up the cost of the BP51’s. You’re not kidding about being spendy…$575 each. Ouch.
Do you already have a CV front drive shaft? My only recommendation would be to keep in mind that when you approach 4” in the front and rear you get into lots more mods to panhards, driveshafts, radius arm lengths, etc. 2.5 to 3” is the easy button.
Telly
Monument
Yeah, i got a Tom Woods DC front shaft, drop brackets, and caster correction already. Just need a panhard riser.
I’m super happy with my Slee 4” lift with his ADS shocks. Without armor his springs would probably be a little stiff and/or yield more lift. If I didn’t get his shocks it would have been BP51’s. My only regret building my 80 was not going straight into high end shocks. Heavy trucks need good suspension.
Telly
Monument
I took advantage of the black Friday deals and pulled the trigger on the Icon dual rate 3" front springs per @Lastresort576 suggestion. I plan to purchase the matching Icon shocks after the checkbook recovers from the holidays. The awesome BP51's would be the cats a$$ but they are just not in the budget at this time. I'll snap a picture after the install...maybe as soon as this weekend.
Nice. Hopefully you’re happy with the suggestion I made. 🍻🍻
Telly
Monument
10mm spacers in the rear and then it will be perfect.
Looks great Doug! I wasn’t sure if it would be too tall. I think the difference is getting the 315s on. Now let’s go wheeling!
PS. I call dibs if you ever want to sell it.
