1977 FJ40 Colonel Mustard
in da house
I replace the corner window rubber gaskets. All the rubber gaskets are deteriorating. Corner windows up the anti keeping the rubber on the window and then inset vs flat glass. But, overall I did it without help.
img_8862-jpeg.153752
in da house
You can see how deteriorated the rubber is and touching it gets all over. Next up is the side windows once I get them in.
RDub
Boulder, CO
That rig is gorgeous! Nice work on the windows.
Fresh rubber on the corners is a special treat. That 40 is so nice!
in da house
Well, I have some weatherstrip and fun stuff to show but before that… two steps forward one step back. Anyone spot the Issue?
RDub
Boulder, CO
Cracked head between 4 and 5?
RDub
Boulder, CO
5 and 6?
in da house
Correct, The bottom circle is the oil feed to the head so the head gasket was installed incorrectly previous to me. If you look between 2-3 you'll see the correct relief for the oil feed...
MonPetiteShoe
RS Club Commander
Aurora
Glad you caught it. Frustrating to have it happen. Did you end up pulling the head because the rocker arms were a little louder than normal or did something get stuck?
How's the rocker arm assembly look?
That’s a bummer but luckily the damage seems limited. Pretty awesome it made it to Ut. And back
