SteveH
You will need a early style bellhousing to easily bolt an FJ60 tranny into an early FJ40 frame. I suppose you could drill/tap the FJ60 bellhousing (as Treeroot suggested), but that may not be worth the trouble. You may also need to move the clutch fork to the other side of the tranny depending on where your clutch line is on the truck. Just pay attention to this as it all comes together.
Also, you will likely find that the tunnel cover rests on the top of the 4 speed tranny and you will either need a body lift or to modify the tunnel cover (more than a little) to clear the tranny. If you let the tunnel cover just sit on the tranny, you'll hear evil sounds in your truck, amplified by the tunnel cover. Mine was unbearably loud. With an FJ60 trans/xfer you won't have a parking brake, either - just an FYI.
