Hey
I started this conversion during COVID and am finishing it up now, so have forgotten some vital things that I was sure I'd remember or wouldn't need as I'd be done quick. I used the JT Outfitters kit, put a Wildwood Proportioning valve on the rear line. I've never had good stopping power since I've put these in. I'm able to lock up the rear drums easily, but not the front discs. I just bled the lines again, the volume that comes through rear lines is much greater than the front, 2x to 3x more. I have the proportioning valve set to lowest braking power for the rears. I can't find info for the master cylinder I bought, but believe it's for a late 70's FJ40 that has stock discs in the front. I'm thinking I may need a different MC, before I do this, is there something else I should be checking? The brake booster is getting vacuum.
Thanks
Gregory
Thanks
Gregory
