- Joined
- Feb 13, 2019
- Messages
- 1,471
I have been focusing my attention on the frame the last few weeks with some great forward progress. I built a jig from scrap metal that locates the frame horns from the cross member. I also measured the stock gussets before I cut them off so I could draw them in CAD and have them laser cut. With the gussets ordered and having given the approach of repair substantial thought I started cutting away all of the damaged material. This consisted of the front frame section and outer frame channel back to just behind the front cross member. Cutting this section of the frame was surprisingly easy and provided the desired outcome. I also did the same with the donor frame section in preparation to put it all back together. Before I get started welding it all back together, I need to pick up some more shielding gas, grind down the welds and prep the surrounding frame. This is the point where I really start moving forward with the build as I just have to put the puzzle all back together.
