The early model cowl vents actually used a cable pull to actuate the cowl vent. It was a poor design, and they went away from it in 1968 to what you see below where the pull shaft attaches to a separate point on the actuator shaft. In my early year, the cable pulled from the other side of the spring in the middle. But when the linkage started to not operate as easily, this cable broke quickly. My linkage was completely frozen.
This knob and cable were completely missing on my 40.
If anyone comes across either type of these knob/shafts, let me know, as I would eventually like to at least have the correct knob. The guy on MUD has some, but they are like $75.
From the next two pictures, you can probably see what caused the linkage to get corroded...as well as the front heater to get all rusty. These cowl vents are notorious for this, and many people either weld them shut, or get a really popular aftermarket cover plate.
Cowl drains don’t work very well with this stuffed in them 😀
Well...I'm stubborn. And I want a functioning cowl vent!!!
So, I cleaned mine up, and I made an actuating shaft that mimics the later style attachment. I still haven't decided whether I want to fork out the $50 or $60 for the CityRacer cowl seal? I might make my own until the ultimate build comes...if it ever does
I did, however, purchase CityRacer’s cowl vent drain tubes. The one on the drivers side was a total PIA to get attached.
After the cowl was functioning, and after watching how nice the throttle worked on Dean's 1968 FJ40, I decided I wanted a functioning Throttle cable again. The problem is, the 1967 had the throttle cable attachment on the 1 bbl carb, but the attachment for the 71 carb moved to the gas pedal like later years. So, I decided to fab up my own cable attachment for the 1971 2bbl carb.
I had this little cable attachment laying around, and I attached it to a little S-hook so it can pull from the same spring attachment point for the accelerator cable. Now, it works like the 1967 would have.
I am not trying to make a museum truck here....If you want to see a museum truck, go look at Barry's '66 FJ45. That thing belongs in a museum, and I hope it finds its way there some day. But, I want a 1967 FJ40 that functions like a 1967 FJ40...and I think this cable pull on the later model carb stays in this same spirit. I think the 1.5F is an upgrade, just like someone putting later model disc brakes on their 40. And I have to make a few mods to keep it looking "stock" and also driveable.
