HoneyBadger
Pine
You're definitely in with a good crew there Travis, that truck is going to be super set up once you're finally done with it. If there is such a thing.. are you going 4.88? or 5.29?
Yeah I know. I've been working towards this for some time now. I can't wait to get 315's on.
I'm putting 4:88's on.
Cut an enormous hole in my fire wall and shoved an EFI harness through it! :)
Rezarf
In Uncle Ben's Shadow
Changed the oil in the FJ40 on Friday last week. The previous record said 2011 was the last time I changed the oil. That can't be right. Even with it having 500-1000 miles in that time, that really can't be right.
You're married now Matt, I am sure it's been since 2011. Wait till the kiddo's start adding up and see how much seat time you get with the 40 :thumb::p:
Drove it to work today, going to pick up a bottle of ZDDP to add to the oil this afternoon. Might work on it this weekend.
Found my smog stuff
Speaking of smog stuff, I rebuilt my smog pump and re-installed it into my fully-smogged 60. Will drive her to the Cruise Moab committee meeting Wednesday night.
Jeff,
Where'd you find the parts for the 60's smog pump?
Jeff,
Um, in the pump? I didn't add or subtract any parts. I took it apart, cleaned and lubricated it and reassembled it. Nothing was particularly worn out, in fact it was less than 3 years old IIRC. It just seized up Monday morning last week when I was going to drive to work. POS Cardon reman....
Definitely different than 40 series smog pumps that have 1 vane, this one has 3! In fact I had a used but functional 40 series smog pump on the shelf, not only was the mechanical mounting different, so was the inlet/outlet configuration.
HoneyBadger
Pine
:wrench:
I got my rear diff and axles reinstalled, along with new seals and o-rings etc. :thumb:
Now all that's left is the front diff and the gear break in.
*EDIT* 1-29-15
:wrench:
Got my front diff and CV axles in last night. :eek:
I'm going to put the gear oil in and torque some stuff down and just generally make sure things are good to go today. Also, I need to track down were these three extra bolts go… That's always fun when that happens… :hill:
ToyodaTocco
:wrench:
*EDIT* 1-29-15
:wrench:
You probably don't need them anyway! Gotta love when that happens
HoneyBadger
Pine
I was stupid. The one bolt was for a little bracket. And the others were for a skid plate. :lmao:
Finished my 2FE build...for the most part
I heard my cruiser run for the first time in 33 days! It now has fuel injection.
Fired up first try. :) My Dizzy is off a tooth though. Going to try like heck to drive it to the meeting, but I have to get more exhaust on it.
Can't wait to feel the difference.
HoneyBadger
Pine
After having done over a dozen short drives and cool downs for my new gears, I decided to open them up on the highway. HOLY COW! It's like a whole new truck! :eek:
She burned up the hill on I-70 without even breaking a sweat and then chewed up and spit out Berthoud pass. I was actually passing people! I'm highly impressed. I should have done this sooner. :D
what gears, what tires?
Fishy
Centennial, CO
:wrench:
*EDIT* 1-29-15
:wrench:
When I did my front diff and locker I was so worried about forgetting something simple I taped a huge piece of paper to my drivers side window with a checklist....I couldn't get in the truck without seeing it first.
RECHECK C-CLIPS?
EVERYTHING TIGHT?
LUG NUTS TIGHT?
GEAR OIL?
DRAIN/FILL PLUGS
I'll never forget starting it up and putting it in reverse to back out of the garage....
HoneyBadger
Pine
RECHECK C-CLIPS?
EVERYTHING TIGHT?
LUG NUTS TIGHT?
GEAR OIL?
DRAIN/FILL PLUGS
I know right? I didn't breathe for those first couple of feet rolling backwards, just waiting for a horrible crunching sound of some kind or another. :D
Can't wait to hear it/see it and get your impressions
