Paul did you do two bottles at once? or one tank after another... congrats on passing!!
just noticed that the limits on my sheet are tighter than those on Paul's sheet. Interesting
Just passed the emissions today with Flying Colors. Even better than when I had the truck new from California.
Replaced O2 Sensors, Spark Plugs, Air Filter, and Rotor.
My good readings....
HC - 0.2567
CO - 4.0977
NOx - 1.1060
Anyone care to guess which one probably had the most impact. I for one think I could have got by with an Air Filter and putting Air in the tires I didn't think to do that when I borrowed Kevin's tires. They were at 15psi give or take
So now I should be good until the CATS fall off.....
Kevin, If you see this as I will PM you as well I am good to go and will take the tires off once the snow stops coming down.
BTW. Michelins are much slicker in ICE than my KM2's. So my take is KM2's are better than the stock tires by far.
3.0 V6
