Tundra mods
AlpineAccess
Fort Collins
I also installed a TRD sway bar last week. I didn't expect such an improvement, but the entire on road driving experience is just...better. Obviously cornering is improved, but also the tail "wag/shudder" going across rail road tracks is gone, truck feels more planted at speed (especially in cross wind?), rebound on potholes, turn in and generally steering feels improvement. So nice.
I am sure it could impact articulation offroad but then again It would be super simple to make a disconnect, or just accept that its a truck.
Install was a piece of cake, Toyota included everything I needed and it was way higher quality than I expected (for what I paid).
Rear Sway Bar - TRD
Part Number: PTR11-34070
1
Maybe the best bang for a buck on dramatically improving road drivability?
The brights on them are really good too. You will be super pleased.
cool, looking forward to this... hopefully get the harness before the weekend.
Next one on my list is the A pillar grab handle- does yours have one? I don't, and would like to add it. need to get the lights sorted then take a couple breaths first though.
Telly
Monument
You guys with your fancy 2.5 gen Tundra's. I've been doing some improvements on my 2010 double cab like TRD rear sway bar, Dirty Deeds cat-back exhaust (went with the 10" system), and Bilstein 5100 shocks with front leveling adjustment. The shocks show up tomorrow and the exhaust shows up in a couple weeks. Check on-line for sound clips on the exhaust...I'm super excited for this mod!
let me know how the bilsteins are
i'm also a true second gen tundra owner, not one of those 2.5ers ;)
New headlights installed. This is the video I followed, which was spot on and easy to do
View: https://youtu.be/xPZbmI4QMQg?si=nZ37wF7cDQx3Ce95
And here’s the after shot…
Telly
Monument
Installed the f/r Bilstein 5100's yesterday. Relatively easy once the upper control arms were separated. Leveled the truck perfectly with 3/4" rake from back to front. Ride quality feels about the same as the factory setup, maybe slightly stiffer ride. I barely noticed any difference in the drive to work this morning. Overall a good upgrade especially with the deal I got on the Bilstein's.
AlpineAccess
Fort Collins
I'm having the same experience with mine. Really like them, set on the lowest notch. What tires/size are you running?
Telly
Monument
I went with the middle setting (1.5" lift) to level the truck. I'm running 33's.
Edit: Just realized you asked about tires as well Jack. I'm running a set of barely used General Grabber A/T's that I picked up on C-List. The tread pattern looks very similar to BFG A/T's. They work well for now and I will likely will go with a set a Michelins after these wear out.
Land Use Coordinator
1st Gen guy here very envious of all of your trucks!! A newer Tundra is on my shopping list for sure....hey Santa!!!!!!
Squishy!
Littleton, CO
Are us 3rd gen guys allowed in here?
I swapped rotors and pads in front this past weekend. My brakes started shaking a few months ago, and have gotten progressively worse.. I know this is super common on Tundras so this is my first attempt at solving it. I went with the cheapest possible rotors and pads from O'Riley's... right around $300 out the door. My rationale is I want to first see if I can discover another issue prior to throwing larger money at this, and if there's another issue I'd rather warp a Carquest rotor than a brand new DBA or Brembo.. feel free to challenge that, that's why we post to the internet.
Convinced my rotors were "warped," I measured runout on each of them prior to swapping and was disappointed things weren't worse. I measured about .0015" on the PS, and more like .0010" on the driver side. factory spec is .002" so I was still within tolerance. Still that's something, so I spent about 30 minutes per side removing gunk from the mating surfaces with a combination of wire wheel, screwdriver, scotchbrite, and brake cleaner... got the outer face of the hub as smooth as I could, and also cleaned up the inside of the rim as best I could also.
I put the new rotors on and used the lug nuts to snug them up, torqued evenly, then measured runout again. Both of them now are under .0005" total indicated reading so I did improve something. Here's the video that shows runout before and after:
View: https://youtu.be/aSqz7eGOBX0
The other thing I noticed was on the hubs there were two sets of indents from the M8 jack-off bolts.. which means I'm the 3rd guy in 100k miles to swap rotors here. I'm positive I took more time than the last 2 guys cleaning things, but besides that I think it kinda speaks to the data you see with Tundra brakes. And my old pads are almost brand new, the old rotors have a few wear marks but they're barely worn, there's no lip on the edge or anything. I am tempted to get those turned, so I've got a quick set to swap over should I need it. I will say I really like this design, better than 80/100 where you're messing with wheel bearings-
My only other observation is the old rotors weren't resting centered around the wheel studs... here's a picture of an old one:
And here's a picture of a new one, which I set into place using the lug nuts. there's a little chamfer on the end of the nuts that force the rotor into position concentric with the studs.
So the question is do the rotors shift against the stud the first time I slam on the brakes? Or will they stay positioned like this? and does that even matter. I guess I'll find out next time I pull a front tire.
Anyway the truck stops butter smooth now.. so hoping that lasts for a while. Will see how I feel when/if it starts shaking again, do I upgrade to something fancy or just swap back the cheap turned rotors? Given how easy it is to replace, I'm tempted to stay on the cheap side. thoughts?
Have you had it aligned recently or ever? As odd as it sounds I've had a similar condition where it seems like the rotors are warped but it was due to an alignment.
no, never. truck drives nice and straight though! and the tires are all super crispy on the edges... I am sure a suspension swap is coming at some point, will do it then.
Squishy!
Littleton, CO
Rotor warping is fairly common on the Tundras. Despite the brake system being bigger than previous gens, they're not oversized for the weight of the truck. Couple that with our mountain roads and warpage is fairly common. (even moreso for the people afraid to use the gear selector)
I have been using R1 Concepts for slotted rotors and they've been great on all my vehicles and certainly help dissipate offgassing and heat.
Telly
Monument
Last week I installed a cat back exhaust kit on my 2010. The kit has 4 muffler loudness options, 6" loudest, 8" loud, 10" quiet, 12" quietest. I went with the 10" SS kit with the Helmholtz resonator. Love it. Has a nice deep tone during acceleration and very quiet while cruiser on the highway. Zero drone too. Performance gains are minimal (+3 horsepower and +10 torque). I would have gone with the 8" mufflers if I wasn't going to be towing my camper long distances. The seller talked me out of the 8" for that reason.
The kit is pricey and I have some buyers remorse because of cost but it puts a smile on my face every time I drive it!
Squishy!
Littleton, CO
The owner of that company really turned me off to buying his products. He was playing the victim hardcore in the 3rd gen pages. It was really weird.
Squishy!
Littleton, CO
Picked up a second hand soft topper yesterday for a couple hundred bucks basically brand new.
Hey Tundra people have a question... I seem to have a pretty solid squeak coming from my serpentine belt.
So I have these three items in my cart:
According to this guy on youtube it's easy to do, and only takes an hour..
View: https://youtu.be/Abze-D3HXmE?si=GjLAqE5qrzY5s4P_
but unlike the guy on youtube, I think I'm going to buy the parts from Toyota, rather than Amazon... does this seem like the right parts list? My noise seems to be coming from the PS of the engine, near the alternator, fwiw... and it used to be a somewhat rhythmic rubbing sound, but then I squirted some belt lubricant stuff on it and made it 10x worse... I could post a video of the noise if someone thinks that's helpful
