Built 1fzfe
$6,000
Fort Lauderdale, FL
Toyota 1FZ-FE 4.5L - Toyota Land Cruiser
Motor was sourced out of a 1993 us spec land cruiser.
I have a fully built 1fzfe motor. The motor was built to handle over 1000hp and over 1000 ft lbs of torque.
Custom bc 284 cams. Shimless buckets. Titanium springs and retainers. Ferrera completion plus valves. Cp pistons 10:1 .5mm over. Spool HD rods. Acl race bearings bearings. ARP main studs. ARP 625+ headstuds. Cometic head gasket. New Oem seals. New Oem timing chain. New Oem water pump. New Oem oil pump. Forward facing intake with 90mm throttle body.
I over built the motor to handle very high horse power, to be durable, and reliable. Selling because my plans have changed and shifting focus to another project. I am open to offers. Can ship anywhere but will have to organize with buyer.
@rover67 - is this an insane price for a custom built engine like this?
Is there a link to this? Unfortunately I’m not on Facebook so maybe it doesn’t matter.Built 1fzfe
$6,000
Fort Lauderdale, FL
It adds up real fast, doesn't it? And that's not even trying to figure up your time as if it's an expense.less than half of what I spent on my full rebuild.
Sorry, I can't find the link. Must have been taken down.Is there a link to this? Unfortunately I’m not on Facebook so maybe it doesn’t matter.
Probably.Flipper?
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Toyota Winnebago Warrior model 321RB, V6 RWD automatic with 77,000 miles for sale. Fresh water pump, ac/heater and stove works. Generator turns on from inside the camper but does not seem to be powering appliances. Can connect to outlet to run electrical appliances. Runs good with adjustable air shocks. My local mechanic has changed lots of parts to try to get it to pass emissions. Does not pass and he believes it is due to the Idle Air Control Valve. Have receipts from mechanic of work he has done. Lowball offers will be ignored.
"believes it is due to the Idle Air Control Valve"We had that problem with 1995 Camry. Can of intake cleaner solved it for under $10
Flipper?
Temp license plate tag
Flare paint peeling…
Lx wheels
High price for sketchy vehicle history…?
Looks like that thing has been wheeled hard, but probably still would wheel hard for awhile.Log into Facebook
Open to offers!
1995 Toyota Landcruiser FZJ80
256k miles.
Factory electronic locking differentials all function good.
Part time spool in the transfer case.
10% underdrive high range gears.
3:1 low range gears.
3 inch lift kit with caster correction plates.
Stainless extended brake lines.
*FULLY REBUILT 1FZ-FE ENGINE* with 1000 miles.
Transmission has a TransGo shift kit installed with new fluid and filter. Also has a Transmission temp gauge.
New radiator.
New water pump.
New fan clutch.
Smittybilt X20 10k pound winch.
Custom built front and rear bumpers and rock sliders
Fender bars for body protec tion.
Full belly skid plates
Front skidplate for steering box protection.
Heavy duty Tie rod and Drag link with new rod ends.
37x12.5r17 Cooper discoverer STT pros with spare. 60% tread
Custom exhaust routed inside the frame rails, no catalytic converter, has all other emission equipment.
Very minimal rust.
Located in Watford City, ND
Open to reasonable offers. No trades Read Less
