http://denver.craigslist.org/car/534124000.html
Is this the one from Fairplay that was going for $4000.00 a few weeks back?
Nice!
Is it yours?
Do it!!![]()
1978 Toyota Landcruiser FJ55 Parts car - $400
http://denver.craigslist.org/car/531958488.html
"I do have it. It is in Walsenburg. Yes it has the 4 speed and the matching factory tcase. I parked it several years ago and it has not been moved since. You would have to put it on a trailer to get it home. Should go right into the FJ40. Thanks Jon
Jump on this one!!! It would be worth it just for the F&R axles you could put them under your '73.![]()
Good advice and after you grab the axles and whatnot you can leave the rusting body back by the ally!![]()
shortly after i get parts off it![]()
Better than the locked axles from Uncle Ben?![]()
Maybe. I forget what Kevin has. This '78 has disc brakes and the rear is fine spline. And you also get a tranny & t-case and the dual circuit brake lines out of the deal.
Hmmm....a 2f, 4 speed, tcase (not split, right?) with disc brake axles? And Ige gets all the spare pig parts? OK, email sent.![]()
Which brings up a thought....what gearing do 55's have? On 40's, the early '78 is a great snag as it has the illusive fine spline 4:11's! (>7-98 3.73 gear change happend) No idea on 55's though IH8RUST!
Made him an offer. What if he takes it??Need to borrow a trailer and haul it back with my 80. Yank out the engine, tranny, tcase (use the tranny and tcase on my 40, keep the 2f for the next club member who needs it. Yank the axles and either use them on the 40 or hold on to them (maybe if I get the 40 in Billings...) then let Ige pick over the carcass.
