Power Tool Thread
Centennial, Colorado
I don't want to clog up the Milwaukee vs Dewalt thread so I thyought I would start a new one for just open discussion on what you have and what you use it for
I have the EGO Blower, Snow Blower (28") and two saws (regular and pole saw)- I really like these. Snow Blower is awesome and wasn't more expensive with the 30% Colorado rebate
For other tools, I am all Milwaukee with some 12V and others 18M.
What I got recently was the Milwaukee Air Compressor. Because sometimes you don't want to start the truck or haul the larger compressor to do things :)
View: https://www.youtube.com/watch?v=jBubgndY9Ko
It works pretty well. I did throw it in the truck for CM in case the dual ARB dies on me, but I got specifically for stuff in the garage and around the house
With all these cold snaps I was worried about my sprinkler system. Draining normally works, but it was supposed to get into the 20's last week. I could use my large compressor which is sized for blowing out my sprinklers. I started thinking about how can I use this small compressor for a quick minor blow out
I just want to connect to the back flow and blow out into the house as draining should take care of the backflow to the yard
Problem with this compressor is it screws on to the tires so it wouldnt work for that
So I bought https://www.amazon.com/dp/B0D1BYZGLJ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 with Valve Stems and it screwed on to the end and then I added a quick connect fitting
https://www.amazon.com/dp/B0FR4WQ94X?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
This allows me to connect to the compressor fittings I screw on to the Backflow valve and then run the compressor
It also allows me to add other fittings if needed. Not planning on using air tools with it. Since I went with the M18 Milwaukees, my air tools have been collecting dust. The only one I still use is the brake bleeder
Anyone get the EGO mini bike? That looks like a cool "tool"
I'm a Makita guy around the garage. Drill, impacts, circular saw, etc... I'd like to get an angle grinder and free myself of that cord. Maybe try one of the portable compressors. I've thought about the coffee maker, OLAF that would be on the trail. Also though about a vacuum.
If I had to start over I'd probably go Milwaukee. They seem to have more options as of late. But with 7 batteries currently I'm sticking with the green for some time to come.
The only property tool I have that is not gas powered is a small Stihl chainsaw. It's fantastic for small jobs around the house. But when real work needs to happen I still relay on dino juice powered tools. I guess that is the difference between city and rural properties. No batter powered snowblower is going to run for 3 hours and clear my drive. Nor will my battery saw drop multiple large trees for firewood. I could probably get away with battery trimmer and pole saw but I already have those that run on gas. Most of my acreage is just mountain forest that I leave alone other than fire mitigation.
While it's not a tool, I've got a Turtle Box bluetooth speaker that I can't say enough about. It rocks and it rocks for a long time on one charge. Sounds good for what it is and its loud. Bridger picked up the smaller unit this winter for work (lift operator). His little one is magnetic and he sticks it right to the lift pole.
Brucker
Why limit yourself? Just buy an adapter off amazon for any brand tool you'd like and run it with your current batteries.
Here is one for a Makita battery on a Milwaukee tool:
Makita to Milwaukee adapter
