Good on ya Dave. Once you figure out emissions it's not a black box. The Toyota emissions manuals help out a lot. If you do get rid of it put it in a box and keep it. I've been dealing with on the 76
Agreed, as long as it's running OK and not impossible to fix I have no reason to remove it. I'll tell ya though the 80s Toyotas (and all cars really) with the VSVs and what-not are real hacks. It's interesting trying to follow their thought patterns to get a solution. Especially with the carb. That's probably the most frustrating part here. By 1985 it was obvious EFI was necessary to achieve the numbers so the carb on the 22R has a lot of ports to do this or that. At least it's a Federal and not a California model.Good on ya Dave. Once you figure out emissions it's not a black box. The Toyota emissions manuals help out a lot. If you do get rid of it put it in a box and keep it. I've been dealing with on the 76
It's oh so close. It would already be if I wasn't all paranoid about trying to figure out the temp thing. It's been hot here this week, 82 yesterday. So we're getting a taste of summer early and the last thing I need is a warped head. This is where having a local dealer worth a darn would be handy. I could have had the fan clutch done already if I didn't have to always wait for the UPS man.Sweet! so it's drivable! New MTB shuttle rig!
I don't know the answer for sure. There's two temp senders, one for the dash gauge and one for an unknown thing. No easy place to tap coolant for an aftermarket gauge, but maybe. Then again I'm not so sure I'm getting bad data either. Oil pressure on 22R/RE is a different animal. That I do not trust at all even with a gauge. The "sender" never changed from dash idiot light to needle...Is the temp gauge like the one in 80's, aka. barely better than an idiot light? Any place to put a standalone gauge to get a more precise reading?
Yeah, definitely. Flipping through the FSM I did trip across the multimeter test for the sender so I'll do that. It's a one-wire, nothing fancy.Is the temp gauge just a one-wire setup? If so, pulled the gauge, ground it, put it in a known temp of water and see what it reads?
Remind us what the issue was with your motor when it was getting hot after the head job?Have you checked the block, head and radiator Temps with an infrared thermometer? The dash guage is pretty inaccurate.
It was reading hot both before and after. The valve stem seals, guides and seats were shot. It ran better after the head job but guage still said hot. I swapped out temp sender and thermostat with no difference. Finally checked with infrared and it wasn't overheating. The guage was just not registering correct. I don't know about the '85, but the Stout guage is adjustable. Once I took it apart I could see how to set it. There's one adjustment to zero it at cold start temp, and another to set running temp, which is ~200°F on the 3RB.Remind us what the issue was with your motor when it was getting hot after the head job?
