Moab pre-run
Those 80's all look a like to me :D Oops, I will go in and fix it in a few............dang you 80 guys are picky :rolleyes::D
That's OK Tom you mini/4runner guys all look the same to us too with your cracked frames and all:weld: was that too low of a blow? I'm a closet mini truck admirer.
You should have just brought up the point about us mini folk throwing our keys in the fire (they burn slow with no electornics on them)...... Oh wait, thats just Tom.
Red_Chili
Littleton CO
Pretty funny that all of us had the issue at once (mine was repaired last year, but developed a hairline crack barely visible, 1/4" long). It is a known issue, that routinely gets ignored or inadequately addressed in almost every case until it happens.
:lmao:
Crossover steering is the cause. I bet minis aren't the only ones to experience this... just sayin'... we should look at ALL the modified vehicles in the forward corners of the frames for any cracking. I bet anyone with a welder, or Moab Outpost, will be busy this year.
RockRunner
Roxborough
No low blows, just fun;). Perry is right, our keys can take the fire:campfire:
Haven't checked my frame yet, but Bill put it together so I bet it is still in one piece :confused: We'll see what it looks like when I crawl under there.
Red_Chili
Littleton CO
Uh... I did not do the IFS steering box install or bracing though d00d, that was done already I think? I don't remember. IIRC I used the Allpro triangle braces but I wouldn't count on those based on recent experience.
In the words of Val Kilmer's Doc Holliday... "VERY instructive..."
I am happy to help; I think we have the nuclear solution to the issue.
RockRunner
Roxborough
We did the total conversion with the steering box bracing. If it is cracked I'll just weld plates where I can and weld the crap out of it. I really think you already welded the crap out of it so I am not to worried, if it is cracked oh well, something to fix.
Red_Chili
Littleton CO
I have a 3/16 plate extending the steering box plate up to the inside corner of the frame. Moab Outpost did that for me last year, for $45. At the very bottom of that is where the hairline crack is starting, right in the corner. My plan is to weld 3/16 to the back of the crossmember with a diamond end to it to not create a stress riser, lay a good bead in the corner between them, then welding in two triangle braces. I might triangle the spring hanger as well, but mine is 1" less drop than Rudy's or Cheeseman's.
1" body lift means there is no radiator clearance issue bracing that inside corner.
It is tempting to run a second DOM tube left to right as a second crossmember... but I doubt I need to add weight to the Chili unless really really needed.
:lmao:
